strange hose on WD45 cooling system
GreenElephant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GreenElephant Quote  Post ReplyReply Direct Link To This Post Topic: strange hose on WD45 cooling system
    Posted: 09 Feb 2011 at 11:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote GreenElephant Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2011 at 11:11pm
allis restorer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis restorer Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2011 at 11:15pm
thats a block heater, and its optional
Go orange or Go home!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2011 at 11:18pm
That's a heater. You plug it into 110 vac when you expect it to get cold and it will keep your coolant warm and make the tractor start easier. I don't think I have ever seen one cobb up like that before. They make ones that go right in the lower rad hose.And yes that is the block drain. I think there is also a rad. drain.
Edited by CTuckerNWIL - 09 Feb 2011 at 11:20pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote GreenElephant Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2011 at 11:20pm
Great, thanks.  That makes sense as there was a piece of cut off electric cord coming out of the cap and some electrical doo-dads under the cap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GreenElephant Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2011 at 11:22pm
yes there's also a radiator drain.  And now I'll need to find a new widget for the block drain if I remove the hose.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2011 at 7:32am
Actually you probably need a "thing a ma bob"  :-)
Still in use:
Reeseholler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reeseholler Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2011 at 8:53pm
either that, a do-hicker or a whatcha-ma-call-it
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2011 at 9:14pm
Maybe a wiggling pin to go in the wobbling hole? :)
I didn't do it! It was a short, fat, tall, skinny guy that looked like me!
This page was generated in 0.131 seconds.
