wd puller
AllisCrazyMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisCrazyMN Quote  Post ReplyReply Direct Link To This Post Topic: wd puller
    Posted: 09 Feb 2011 at 10:55pm
Wanting to build a WD for pulling. so i would like some input on what to do to get more power out of it? i heard use WD45 crank, but can you use high compression pistons with it?  what rods to use? head>? thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2011 at 10:57pm
Let's start with a question to you......how much money do you want to spend???..because that's ultimately what it boils down to.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisCrazyMN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2011 at 11:07pm
got about 1000 to spend on parts. my work has a machine shop so i can get a good deal there. just want to get good power out of it, but make it so it still looks stock, so i can run in the stock class.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2011 at 10:52am
thats not really a budget to do any performance upgrades with other than a thorough rebuild. wd45 crank wd45 power crater pistons leave the first compression ring off on a 8 inch rod  . If you have any money left buy a bigger carb a moline g carb and a good ignition system to light the plugs . Oh youll need 40 dollars or so of race gas every pull you attend. .
Edited by mlpankey - 10 Feb 2011 at 10:52am
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2011 at 11:11am
Use a WD45 crank, manifold, aircleaner, & carburator. Have a good machine shop surface your head & give it a proper valve job. Use 41/8" sleeves & 175 replacement "Power Crater" pistons with your WD connecting rods. Either a mag or distributor will work fine. For a "stock appearing" & sounding setup this will make a competitive puller in a stock un-cut tire class that will run great on regular gas. Stock WD45s always do well in these classes!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisCrazyMN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2011 at 11:58am
Thanks for the input guys. i can go over 1000 bucks i just want to get the main stuff done then add on as i go. so what mods will i have to do to my block to make the 45 crank work in there? different size bearings?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2011 at 11:59am
nope bearings are the same until you get to the d17 style 226
Edited by mlpankey - 10 Feb 2011 at 11:59am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisCrazyMN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2011 at 12:04pm
thanks for the info guy's, should i worry about a different cam?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisCrazyMN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2011 at 12:08pm
where is the best place to buy these "power crater" pistons? anyone have a part number for them?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2011 at 12:15pm
yes you need a different cam . are you going to use 8 inch rods? if not use your wd pistons with the 45 crank.
