7040 seized engine
idaho dry farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote idaho dry farmer Quote  Post ReplyReply Direct Link To This Post Topic: 7040 seized engine
    Posted: 09 Feb 2011 at 7:18pm
Okay guys,
have not posted on here since the old forum was goin.  have a brown belly 7040, dad bought 10 years ago, was being used by neighbors this summer, oil plug came out.  seized her up, pulled pan and head today, #4 bearing is cooked to the crank.  i have a 80 N6  motor,  will that crank work or am i looking for another crank.  or can i have this crank turned i wonder?   dont really want to get rid of her,  for some dumb reason i like that tractor.  brother works for local agco dealer so i can get engine kit from him at good price.  just wonderin what to do with the crank.
thanks,
idaho dry
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2011 at 7:37pm
Do not use the old crank...N6 crank will fit.....probably throw away the bad rod and have others checked for cracks and re-sized......new rod bolts are a must.....make sure all main caps fit snug in the block and don't fall out.
CORLEWFARM View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote CORLEWFARM Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2011 at 5:50pm
would not be suprised if a main has spun
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2011 at 7:21pm
I wouldn't be surprised either, but sometimes a guy gets lucky.
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2011 at 9:27pm
just use the combine motor
tcorbett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tcorbett Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2011 at 9:07am
Just saw that someone in Idaho was selling at 7040 engine:
Used 3500 Model Engine for 1976 ALLIS-CHALMERS 7040 TRACTOR
This page was generated in 0.313 seconds.
