Farming advise
KC-WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KC-WD45 Quote  Post ReplyReply Direct Link To This Post Topic: Farming advise
    Posted: 08 Feb 2011 at 2:52pm
 I'm looking for some opinions. Last fall after I finished restoring my first tractor (wd45) I caught the farming bug. Currently I have 15 acres that I have plowed and plan on planting beans this spring. I am not looking to become a proffesional farmer but eventually I would like to be working about 40 acres. So the question is if 40 acres is the goal what equipment  (tractor, plow, planter etc.) would you put on the must have list. I like the 190xt but I'm looking for opinions and they might not be orange. Thanks.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2011 at 2:57pm
A wd-45 will do 40 acres and all you need is implements.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KC-WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2011 at 3:05pm
 But would you want to? I plowed 15 acres with a 2-16 and it took quite a while.
RSponenberg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RSponenberg Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2011 at 3:05pm
For 40 acres your WD45 will do fine as your tractor.With the equipment you listed you'll also need a harrow or disc as a must have,and a sprayer would be nice too!!!
 I farm 108 acres with 2 WD45s and a CA... Can only use 1 at a time as there is only one of me...
Edited by RSponenberg - 08 Feb 2011 at 3:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote KC-WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2011 at 3:08pm
Right now I have the wd45 a 3-16 that I'm not using the third on and an 8' disc. I was thinking I was under sized but it sounds like I might have the basics covered.
Steve M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2011 at 3:18pm
Not too far from my house there was a guy that was retired and decided that he wanted a hobby, so he bought a 150 acre farm just 3 miles down the road and then went and bought a WD45 and implements to match it. Bought an old Gleaner combine and farms the whole place with just that equipment. Yes, it does require alot of seat time but thats what he likes AND his equipment investment is just peanuts compared to to other farmers around him that have the newer bigger stuff but they both get the same price for their crops when they sell.  He could afford to replace his whole tractor for just an engine repair on their equipment.  You ought to see the smile on his face out there putting in the seat time!
Post Options Post Options   Thanks (0) Thanks(0)   Quote RSponenberg Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2011 at 3:25pm
 8 foot to 10 foot disc is fine for a WD45 get too big and you wont do as good a job or wont pull it at all. Plows I pull 3 bottom 16" semi mounts in 2nd gear no problem..
Beans right now are $13.58+/- but as the old saying goes " Takes money to make money"  When you go buy seed,fertlizer and spray and pay the combining you'll see!!!
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2011 at 3:27pm
My vote would be a 6080 or even a 6060 if WD's are like D17's a 6080 will be a lot nicer.  The 6080 will run on a fraction of the fuel and if it's got better hydraulics and more comfortable.  On the other side of the coin my grandfather made a living farming about 80-90 tillable acres with a D17 and C.
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2011 at 3:35pm
Back in the 50's, my Dad ran 280 acres with an M Farmall and an R Moline.  The M did most of the tillage work including pulling a 3-16 plow.  A good WD-45 should be plenty, unless you only want to work the 40 acres on weekends.
Mark
GTH-L Simplicity
Post Options Post Options   Thanks (0) Thanks(0)   Quote RSponenberg Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2011 at 3:37pm
6080 is over kill
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2011 at 3:52pm
If you don,t like seat time you wont like farming. We cultivated 50 acres with a farmall cub once . Run two tanks of gas  through it in one day , lots of seat time
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2011 at 3:55pm
I have a 7060PS,D17 gas for 5 acres!!
acd21man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2011 at 4:48pm
my great grandpa farmed with a 1952 red bely ford 2 bottom disk plow and a disk (dont remember the foot) and cultivated to,.......he had then 100 AC then my grandpa bought a D-17 series 4 gas 3pt with a 3 bottom ... then later my dad started to trade on EQ and now we farm with a 7000 1979 220 1973 D-21 1969 WD1952 WD45 1956 WD45 diesel 1954 and 2 D-17 diesels 3pts both 1967s now we farm bout 450 ACs moving up in the world lol
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2011 at 5:00pm
My grandfather and uncle  farmed over 600 acres with four  8N Fords and an Allis WC (WC never had the cornpicker taken off of it)....and they only believed in farming till 6:00 at night! I'm helping him average out the numbers LOL!
ALLIS EXPRESS!
This year:
Reindeer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reindeer Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2011 at 5:13pm
I,ve spent a lot of seat time on the smaller tractors <40 HP, and the jump to > 50 HP is a big one if you are doing your farming part time on 40 acres.
 A D-17 or even D 19 would be sweet, and 170-175 are good solid tractors with standard hydraulics that will run any kind of plow or disc.
I farmed a few hundred acres part time, takes a lot more tractor to do things part time:)
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2011 at 6:56pm
Doug, You have all the tractor you ed need for a 40 acre farm, Like the guys said above get a two or four row planter, 8' to 10' disc, a good sprayer, and a old E Gleaner combine and your good to go. A 190XT is a little over kill and you'll get done to fast! LOL
Reeseholler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reeseholler Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2011 at 7:07pm
For me, I think it depends on two things. How much time you're willing to put in and how much money. If your going for just something for "pure hobby" and a little extra cash, I think the 45 would be sufficient. It may take awhile but I think with at least that tractor that the maintenence is simple and you don't have to have as big of a storage unit for it. If your going more on the money side, I imagine anything around 60-70 horse would do you. Me and dad started baling hay with a John deere 50 and a 14T baler and now we're up to a Ford 6700 and a IH 440 baler with a thrower. If you have the time, I think I would try the 45 for a little and see what you could improve and then what you're willing to put the money into to improve that. If you want a bigger tractor, bigger implements go along and so does the parts. for that amount of acres, I imagine it wouldn't be used that hard but I think if you had a 60-70 horse tractor and the 45 you would have quite the small setup. Just my thinking. I'm probably a little off my rocker but just trying to throw some ideas out there.
Eric[IL] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2011 at 7:16pm
It seems the old days everyone talks about on this thread had good old weather conditions.  I remember the same.  Good planting, mowing, spraying, & harvest conditions where 3-6 weeks were favorable for any or each of those tasks.  Today, especially the last 3 years, have had difficult weather patterns.  Some of these patterns developed some seriously wet soil conditions throughout the whole growing season.  Get that WD45 & 8' disk hooked up, run a few quarter mile passes, then turn around to see rain barrelling down on you.  Put that scenario into late June and that 40 acres could seem like 240.  You may want to upgrade to bigger cheaper hp with wider equipment?  I am thinking something versatile like a good AC200 tractor with 18-20' equipment.  The 301 gets good fuel economy.  Around here, that size equipment used to go cheap at farm auctions?  Scrap iron prices, & high grain prices have raised it now though...   That AC200 could also haul grain wagons to the elevator.  It should be able to do spring tillage, NH4 application, plant, sidedress, spray, row-cultivate, mow, haul grain wagons, & fall tillage.  You're right, it is overkill if the weather is good, but if not then even a 7020 or 8010 would be a wish list for that 40 acres.  Actually a 7060 might be just as cheap to purchase.  It would use more fuel, but could handle equipment with ease.
farmer0_1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer0_1 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2011 at 7:58pm
dad farmed after his 8-5 job of being a lineman.  we have 40 acres here at home and alot of years he had over 100 acres.  two sixteens plow jd 420 johnny popper.   10 pm he came in alot of night and if i was lucky i got to ride a TO 20 doing roller harrow work.  you will be fine.
singingpig View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote singingpig Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2011 at 8:23pm
I agree with Eric....overkill is good.  I only farm 20 acres and use a 140hp  and a 62hp FWD.  I even bumped my G up to 23 hp lol.  So often the difference between making a profit and losing money is having equipment big enough to do the job during a small spell of good weather. Timing is everything.
I would go through 1 or 2 seasons with the equipment you have though, make a little money, get some experience and then look to upgrade.  Your decision making will be better after a year or 2 of experience.
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2011 at 8:29pm
If you wanted to upgrade at all, I would consider a 180/185.  They are very good, efficient tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2011 at 11:02pm
X2
And reliable as an anvil.  With the extra power, you might still have time for fishing on the weekends!!
Mark
GTH-L Simplicity
GARY(OH/IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GARY(OH/IN) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2011 at 11:17pm
My Dad farmed 300 ac. in the 60's with the big tractor a wd45. 100 ac. at home and 200 ac. 19 miles away. Pulled the wd45 back and forth with a tow bar. Other tractors were AC wd, and unstyled wc, JD ar and a. Seat time=alot. Cheap labor=me.
Ben (MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2011 at 6:03am
KC-
I am going to ramble a bit, but I want to see you suceed so I'll share my thoughts. I farm 100 acres of no till beans and corn. When I started farming on my own I had a 180 diesel, 4-16 Ford plow, 12' IH disc, 12' IH field cultivator and a 6X30" JD 7000 planter for 50 acres. Since then I have had two AC 7000s and have just traded up to a black belly 7060. I have a JD 6X30" 7000 planter set up for no till. If you are farming for enjoyment tilling is the way to go. If you are farming for profit no till deserves serious consideration. I farm because it is in my blood but it must support itself, the last couple of years have been very profiable. My AC tractors have all been low cost to buy and operate and have earned their keep many times over. When it comes to planters JD is hard to beat. Good luck, to me there is no feeling greater than making that little seed grow into a productive plant-it is truly a miracle.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2011 at 6:48am
You are going to waste way too much time changing impliments.  You need a tractor for plowing, a tractor for disking, one for planting, another for cultivating and another for a wagon puller.  You'll need five to start with.  Maybe another for mowing.  The possibilities are endless to acquire more orange.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2011 at 7:35am
Don't forget one for just driving out to the barn, to get the right tractor!!  :-)
Still in use:
bill2260 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bill2260 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2011 at 7:43am
I have a couple of neighbors who has a specific tractor for every job. Almost never unhook. Part of the problem with dairy farm profitability.
Seriously, if you are a young man you can make a wd45 work all day. In the process you will run 30 gallons of fuel thru it and sleep well that night if the vibration and ear ringing subside enough to fall asleep. I did that till I was 25. Now 52 and not interested in that anymore. Lot of goood cheap horsepower out there.   Bill
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2011 at 7:49am
If you have a full time job get a 190xt and matching equipment or something close. Much faster but first see how 15 acres works out first. Might be all you care for and will still give you a chance to work the equipment you have.
Edited by Lonn - 09 Feb 2011 at 7:50am
Wink
I am a Russian Bot
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2011 at 7:52am
If you like seat time, just start with your WD-45, a 3-14" SC plow, 10' disc and 4-row planter; have someone custom-hired to combine.  After a year or two of saving money and having fun you decide how much more leisure time you want and how much bigger stuff you want to buy.
My 2 cents worth...
Brad(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2011 at 9:59am
I had a long post, but my puter shut down.  Here goes again.  You can start with the wd-45 and see how you like the seat time.  I would look at a 7060 for a tractor, like Ben(MI) said.  Around me, they are cheaper than a 180, 190xt, 200, and all amaller 7000 series tractors.  I would go with a White planter and no-till.  I don't know much about JD planters, but the Whites are cheap to maintain.  The older 5000 series whites are cheap, but will need no-till coulters if no-tilling.  Our 6000 series doesn't need the coulters to no-till in our soil.  Get a decent sprayer, or hire it done.  You might need to take a pesticide applicators training class to purchase/use most chemicals.  Otherwise hire it done.  A small combine can be found cheap enough, and that is the best part of farming for me.  Getting to see your crops yield first hand is good info.  Hiring it done is an option, and around me it runs $25-30+ an acre.  There is no maintainance when hired done, and they might supply a grain cart or truck.  Lots of ways to do it, and none are wrong.  All depends on how much time and money you have to put into it.
This page was generated in 0.099 seconds.
