D21 Engine Kits?
T16 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote T16 Quote  Post ReplyReply Direct Link To This Post Topic: D21 Engine Kits?
    Posted: 07 Feb 2011 at 8:57am
Fixing up an old D21 series one and need to pruchase a Overhaul kit for the 3400 series 426 cu in motor. What do you recommend and why? How much?
Thanks!
Hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunter Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2011 at 2:26pm
i would recommend ordering the kit from a dealer that sells ac parts or if u know what size pistons sleves and rings u need u could get them from any place that sells them. it would probably run for about 900 to 1000 dollars if u are lucky maybe 800 but things are always more expensive online so dont order them from a website unless u really have to.
T16 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote T16 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2011 at 5:20pm
Unfortunately, I'm not blessed with that great of a local dealer. But I do appreciate your reply.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunter Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2011 at 5:32pm
yup how close is the nearest dealer
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2011 at 5:41pm
The high compression kits really can do wonders for the 426s and 301s.  I think Herschel Adams is the company that still makes the M&W designed kit, but PowerMax makes a high compression kit, but at least for my 301 kit, they use a standard upper ring, where the M&W kit I believe uses an L-shaped ring to help boost cranking compression at those lower speeds.  All the parts for my 301 from Power Max were of name brand except the pistons and sleeves, which they told me were made in their factory here in the US (forget which state).  Good luck!
Hurst
1979 Allis Chalmers 7000
5800 Hours
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2011 at 7:11pm
where you located? I have a very good local Agco Heritage parts dealer here, and he also deals in Howard Enterprises, as well as others. The 3400 kit will end up being the same as a 3500, I doubt anyone still makes the early style na pistons, if there was ever a difference. pm me if you want his contact info. Ed.
T16 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote T16 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2011 at 8:58am
I'm in North Dakota. Thanks for the info.
This page was generated in 0.240 seconds.
