wd45 missing on idle?
Joel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joel Quote  Post ReplyReply Direct Link To This Post Topic: wd45 missing on idle?
    Posted: 05 Feb 2011 at 2:02pm
Hi, I have a 1953 allis chalmers wd45 it is missing badly on regular idle, and also is starting to miss on high idle. It has new plugs, wires and distributer cap. The valves have been adjusted, and the carburator has been rebuilt. Any ideas on what else it could be?
Thanks, Joel
BILLP-SE-MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BILLP-SE-MI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 2:29pm
My WD did the same thing it drove me nuts. Found out the gaskets on the intake part of the manifold  were cracked and alittle piece was missing. It sounded like a johnny popper 2 cyl. I checked it by spraying Gum-out around the manifold. Hope this helps
Have a good one BILL P
Edited by BILLP-SE-MI - 05 Feb 2011 at 2:30pm
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 4:25pm
I assume that you have the plug wires on correctly.  You might 1st check to find out which cylinder is missing.   The change in sound of the engine running will help.  Can do this by grounding out different cylinders with it running.  You might have a valve hanging up, burnt valve or a manifold leak.  Hope this will give you some ideas.  -  AL
Joel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joel Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 4:54pm
Thanks for your help!
