d17 tires
ironac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ironac Quote  Post ReplyReply Direct Link To This Post Topic: d17 tires
    Posted: 04 Feb 2011 at 8:22pm
im restoring a d17 and im confused on what size tires to put on it. the old tires are 5.50-15-sl in the front and 16-9-28 in the rear. i dont know if i should get a new set of the same sizes or go with what tractordata.com says it should have.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 8:26pm
Tractor data is not always correct.  my 17 has 16.9x28s on her, and that's on a 15" rim, looks really good.  The 14.9x28s will start to make it look like the WD45 rear depending on your rim width, which will look out of place. IMHO not fact.
Still in use:
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 9:02pm
16.9 x 28 and 6.00 -16 look good on the early series....18.4 x 28 and 9.5L-15 look mean on the Series IV.
I put a set of 14.9's on my early series and it looks a little anemic...
ALLIS EXPRESS!
This year:
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 9:56pm
I thought all 17's had 16.9 rears.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 11:04pm
Even the 170 operators manual lists 14.9 x 28 as an option on them.....they really look small on a 170!
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote ironac Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 11:08pm
uploads/4197/IMAG0137.jpg
i think i will stick with the same size its got on it. looks a little meaner
Post Options Post Options   Thanks (0) Thanks(0)   Quote ironac Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 11:12pm
tires are a little low in that pic. it had been sitting in the yard for about 7 years. finally decided to push it in the garage and work on it. found out my dad had thrown a rod in it and it was all locked up. i got all the engine work done on it now and its all put back together and running. having problems with it cutting out if i give it to much throttle to fast.
EdIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EdIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 12:21am
Eldon,
     What brand are those 14.9 - 28 tires and where do you buy them?
      Thanks     Ed
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 10:18am
My Series IV has 16.9 x 28s and 7.5 x 16s.  Looks great...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 11:14am
According to the owner's manual for my early D17, the 14.9-28's are the "standard" size with the 16.9-28 being optional. I'll bet most D17's had the optional 16.9's put on them. That's how mine is.
Dean/MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean/MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 11:18am
Our '67 Series IV had 18.4x28's on it from the factory. It was purchased new in spring of '68 and had been @ the MN state fair the previous year. I always liked the way it looked with those big tires on it and it did float quite well also.
Edited by Dean/MN - 05 Feb 2011 at 11:19am
HD16,917H,185,7050,8030FWA,8050FWA
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 11:19am
My 59 wide front D17 has, 16.9-28s and 6.50-16s. My 57 narrow front has 16.9-28s and 5.50-16s.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2011 at 8:01pm
Bought a D17 diesel with factory 14.9's on it.  It was a lot happier with the 16.9's I found on a scrapped D17 gas I found.  The 14.9's went on my 45 diesel.
