Tire chains
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Topic: Tire chains
    Posted: 03 Feb 2011 at 8:33pm
Went and looked at a set of tire chains today for my tractor at a consignment auction this Saturday. Could someone measure their chains so I know how long they will have to be? Luke
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 9:24pm
Rough way to measure would be chalk a circle on sidewall maybe a little larger than the half way mark from rim to tread then work a tape measure around the circle.They would need to be a little longer than that to account for connecting.If too long you can always shorten.Tie up loose links on inside(next to fender) with several wraps of bailing wire apiece.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 10:18pm
Steve, dagnabit, where you bin, bailing wire has bin replaced wit zipties for quite a while now! LOL
I am still confident of this;
Wait for the Lord;
skip(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skip(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 10:25pm
i've never put chains on before, but i'm assuming a crude, ballpark measurment would be to measure the diameter of the tire and multiply by 3.  measure the width of the tire and add a few inches....maybe 6".  again, i have no experience with chains, but if i had to know right away, that's what i would do.....unless of course someone that knows tells me otherwise.
or, call a tire chain place and get the chain specs for your tire
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 10:40pm
P = 3.1416  So if you have a 24" rim the length of the side chain would be about 1/2 width of the tire out from rim or say 28"
 so 32 X 3.1416 = 100"
remember 4" on each side of center of circles is added from rim
this is figuring side wall is 8" high
Now cross chains would need to be width of tire face + 8" (4" each side)
so say 13" + 8" =21" length.
We find the length of the circumference of a circle using the formula:
C = 2 πr
We take the radius, multiply it by pi, and multiply by 2.
Edited by Coke-in-MN - 03 Feb 2011 at 10:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 11:06pm
Well...if I'd seen this post earlier I could've measured mine cause I drug them out of the barn this eve and put em on the 45 cause we got ICE out the butt with a little snow for good measure.I ain't taking them off to lay out and measure.Left over snow is glazed down with enough ice I can drive the tractor over the old drifts and barely sink in.Rain sleet and freezing rain for 2 days really made a statement.
