Begining a D17 restoration
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Topic: Begining a D17 restoration
    Posted: 03 Feb 2011 at 7:05pm
Well I thought it was time to start my 2nd restoration.  The first was a 45 way way back in middle school for 4-H, I did a pretty good ~95% restore for a kid.  Now that Dad's getting out of farming, and I am stuck in the city, I am getting the bug to do a full 100% nut and bolt true authentic restore.  What I am wondering is where do you find the details about what was orriginal/factory on the different series say for things like guage faces, and decals?  I have ordered C.H. Wendell's book, I hear it is full of good stuff.  Any other ideas?
I know the later model tractors really well, wrenched on them for years, but the older stuff, didn't need much work, and didn't get worked as much, and while the wrenchin is easy, I just don't know where to find out the details about correct vs. incorrect parts.
Also 2nd question.  My manifold has the threads in the exhaust outlet, what was this used for, I have never seen a threaded muffler, is this correct for a series III, or was it suppose to be smooth bore?
Thanks in advace for all of the info and help that will be needed.
Anthony
Still in use:
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 8:36pm
Don't know when,but last 17's had pipe screwed in manifold and the muffler sliped on with a clamp.I think it started with the quieter oval style but don't know.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 8:40pm
Series III & IV D17 had a the exhaust manifolds with a screw in stub pipe.  The oval mufflers with slit sided inlet pipes slid over the manifold stub pipe and were held on by a muffler clamp.   Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 11:03pm
Here is how your gauges should look.  If you want the trim that goes around them, send me a message.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 6:00am
I love that panel!!  Thanks for the offer, but this is going to be as factory as I can get it.  Thanks to everyone for their answers.  I am sure I will have many more
Still in use:
Allis Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Fields Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 6:39am
Srries II 24001 and up or 32000 and up. My 1961 had the larger ROUND muffler. That used a treaded pipe 1.5" , use a black gas line pipe to screw into the manifold. It won't rust and break like the galvinized one. Get one long enough to cut in half. You want no threads in the muffler opening. Also use a die grinder to keep the opening free from opstuction. once you find out what year it is, look on ebay for the dealers sales brocher. there will be very valuable pics and info. And it would be cool to display it next to your perfectly restored D-17
Allis orange blooded by family. Allis Diehard by choice
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 1:26pm
Thanks, the sales brochure is a great idea.  BTW its s/n 40184 which makes it a '62 or '63 depending on which serial number reference you look at.  I am currently under the impression it is a '62 model Series III.  Are there any other physical differences that tell you which series it is?
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 1:52pm
Anthony - Series III started wtih SN42001.  If your SN is 40184 it would be a late "Series II" which is an unofficial designation.   Here's a couple items that will clearly identify if your tractor is a Series II or III:
* Series II had headlights mounted to the front radiator shell, Series III had fender mounted headlights
* Series II had the hydraulic fill cap on the right side of the torque tube near the belt pulley plate.  Series III combined the hydraulic and power director compartments and used the single oil fill dipstick to the front left of the gearshift.  The oil fill on the right of the torque tube was eliminated.
* Series II had no hydraulic filter.  Series III had a 2nd hydraulic filter on the right side of the tractor under the gas tank.
It is not uncommon for someone to have repainted an earlier Series I or II D17 and used D17 Series III or IV decals on the hoods.
If you post a few pics of your tractor we can probably help you more.
Mike
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
LannyMTN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LannyMTN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 2:12pm
Dseries4's panel is as near factory as you can get, besides finding NOS. Good luck.
Lanny Mid-TN
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 2:16pm
Hey Lanny, are you saying it should have the polished steel behind the guages?  Mine didn't, my 19 doesn't eigther, and haven't looked at the 17 diesel?
Thanks again for all the help.
Still in use:
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 4:28pm
Also series II have a oil bath  air cleaner, Series IIIs and Ivs have a dry air clearner above the engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 7:05pm
Isn't there a book out there called "Original Allis-Chalmers" or something like that? Seems like maybe what I'm thinking of was a co-operative effort by maybe Guy Fay and Larry Swenson?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 7:47pm
Brian, you are right, but that book's title says it ends in '57, so I don't know if it would help me or not?
Thanks,
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 10:47am
Orange Blood, these panels were used on most (if not all) D15s, D17s, and D19s.  Originally, they were turnings on a piece of aluminum.  However, they do not stand up very well over time.  So I started making mine out of brushed stainless steel - always looks good.
As Lanny said, you cannot get the original pieces anywhere - I looked everywhere too until I learned how to make mine with the turnings.  Like you, I wanted the tractor to look as close to stock as possible.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LannyMTN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 1:18pm
Orangebloood,
My Dad bought a new D-15 in the spring of 1961(the first one the local dealer got delivered to him), that had the panel. My sons have a 12xx serial number D-19 in the shop being repaired, that has the panel. I have D-15 4xxx, and D-15 series 2, 21xxx that both have the panel. My Dad also bought a D-17 series 4, in 1967 that had the panel. Another customer has a D-17 series 3, at my sons' shop, and it has the panel also. But, my 1958 D-17 LP, doesn't have the panel or an operation meter/tachometer. I have not seen this discussed before. Possibly, the panel started with the color change from PO 1 to PO 2, and may or may not, be tied to the optional operation meter/tachometer. Have a good day.
Lanny Mid-TN
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 2:14pm
If you get the chance, post a "before" picture of your D17... otherwise me may not believe you when you finish ;)
momaallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote momaallis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 3:10pm
sure would like one of them restored ones ....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 3:50pm
Hey guys thanks for the info on the dash, maybe the D-Series I have, the panels just didn't survive.  Anyway, I will be posting pics soon, you will be shocked.  This tractor suffered a gas tank fire about 15 years ago, we paid the owner the ins. salvage price, and it's been sitting in our yard since.  It was just overhauled by Allis prior to the event, but found that it now had water in the pistons, from condensation I guess, it has always had a cap on the exhaust.  Oh well, I love a full tear down, and rebuild, but my wife will be sure to hate the bill.
Anthony
Still in use:
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 5:36pm
D17 III and IV and all D19 had them. Not sure if all series II D17 had them but mine does.
This page was generated in 0.054 seconds.
