ALLIS TBH backhoe attachment
allisman3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisman3 Quote  Post ReplyReply Direct Link To This Post Topic: ALLIS TBH backhoe attachment
    Posted: 03 Feb 2011 at 8:17am
Ran across a tbh backhoe attachment recently.
Looked to be really heavy duty. Does anyone know what they fit?
Anyone have Pics?
Has a large plate with pins and uses a single wetline.
Adrian
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 9:15am
Would need more info , or picture . AC made the 615 hoe that went onto HD4 machines , was a 2 stick unit with 14' hoe. They may have used it on tractors also .
 Used a Cesna rotary piston mounted on top of frame to swing hoe
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisman3 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2011 at 9:59am
Hey Coke,
I finally found a picture from a parts manual.
Hope this helps...I still cant tell what it is mounted on
but there is a mounting bracket. on the unit I ran across.
Any of you guys got one of these.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2011 at 11:28am
That is a smaller unit than the AC 615 unit i have , the swing looks like it is under unit and the legs are a different style. the 615 is a 14' dig depth hoe.
 The 615 has a plate with ears on top and bottom for pins to index into back of machine on what was called tool carrier. A diverter valve was used on power unit so backhoe valve body by-passes the machine valve body. A supply line went into the diverter valve and the return line hooked to return side.this took the other valve and flow control and regulator all into hoe valves. Quick connect couplings were used .
Edited by Coke-in-MN - 09 Feb 2011 at 11:40am
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisman3 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2011 at 3:06pm
The picture on the manual looks like it is mounted on a wheel loader.
Sorry, Just fishin, don't have a clue what the darn thing mounts on.
Tag says <hydrahoe> never heard of it.
Allisman
This page was generated in 0.115 seconds.
