AC 7060 not started for several years
tym2fish View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tym2fish Quote  Post ReplyReply Direct Link To This Post Topic: AC 7060 not started for several years
    Posted: 03 Feb 2011 at 7:09am
Hi,
What kind of suggestions does everyone have on what to do first before I try and start a 7060 that hasn't run for several years.  I will change the oil before i try and start it, just wondering what else I should check and or replace.
Thanks
bakwoodsfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bakwoodsfarm Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 7:12am
how many is several years?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tym2fish Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 7:25am
Oh i would say at least 10 to 15 years
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 8:01am
You need to check the air cleaner and air filter housing for mice or bird nests, the exhaust should be clecked for same type of stuff, then as long as you make sure there is not water in any of the oil galleys fire her up.  Your idea of changing the oil first is a good idea, but you really need to change it again while it is at operating temp, this will allow the suspended particles to come out "with" the oil, rather than stay in the pan.  Let the tractor get good and warmed up, so it burnes off any water in the oil, that may be sitting on parts up in the engine.  But unless it has been open to the enviornments (open lines, no exhaustcap, e.t.c.) you shouldn't have to much to worry about.  Just let it idle for a while, say 5 mins, to get every thing recoated in oil, i.e rocker arms, before you start "playin" around with her.  If you don't want to clean up a big mess, then put a non flamable tarp over the hood and roof, she is going to spit a lot of carbon out of the exhaust when she first runs, since it has has a long time to dry out.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 8:05am
One thing I forgot, is mice nests inside the dash. I tried to burn up a D-21 once after a long sit, becasue once she was running the mice nest packed in the voltage regulator under the dash started to work too, i.e got hot, and started a small fire.  Fortunately I smelled it early, shut her down, and was able to dig it out.  Mice love tractors sitting around they are perfect "houses."
Edited by Orange Blood - 03 Feb 2011 at 8:06am
Still in use:
JERRY-KS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JERRY-KS Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 8:29am
I believe I would remove top of injection pump & remove as much varnish as possible & fill it with Dexron product, then install new fuel filter & likely drain fuel tank & put in new fuel.  It will need all the help it can get to keep from having damage to pump & injectors.  You may need to do an injector job as well.  JERRY-KS
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 9:19am
Im with Jerry.  I have a 7060 that had been sitting a long time and had a cylinder stuck.  I lubed everything up real well as I re-assembled, and drained fuel and changed filters too.  The tank ends up with a lot of crud in it from the fuel disintegrating all those years, so you will probably have quite a bit of trouble with that (I have!).  Other than that, like the other said, it will make a mess when it first starts and dont head to the field with it right away!  Good luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tym2fish Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 11:28am
Thank you everyone,,this is great advice.  I will do all you suggest, it won't be a working tractor much,,just odds and end stuff,,scopping snow and stuff,,need a loader yet for it tho :)
bill2260 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bill2260 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 12:16pm
Let us know how it goes. Bill
Post Options Post Options   Thanks (0) Thanks(0)   Quote tym2fish Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 3:55pm
Thanks,,i sure wiil,,won't be until the spring gets here tho,,i live in Iowa.
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 4:19pm
7060!,wow,  that's a big snow shovel!
Post Options Post Options   Thanks (0) Thanks(0)   Quote tym2fish Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 4:34pm
Yup,,nice a comfortable too with the cab and heat in the winter here :)
Mike Kroupa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Kroupa Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 4:58pm
I would do what the guys said plus pre-lube the engine before you crank it over. This would ensure that you have fresh oil in all the right places before you fire it up. good luck, Mike
