Blizzard CRAP
KC/WD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KC/WD Quote  Post ReplyReply Direct Link To This Post Topic: Blizzard CRAP
    Posted: 03 Feb 2011 at 6:57am
Up in Northern Missouri we got 10-14 inches of snow with nasty winds causing drifts from HELL! My property was a deep sea of snow with nowhere to push the snow to with my WD, heck got her stuck a couple of times. It sure was discouraging!!! This kind of condition proved to be too much for my tractor. Has anyone used a snow blower behind a WD before???
I've got anal glaucoma, I just can't see my butt going to work today!
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 7:15am
Be glad you have snow to push. My drive is ice, blade won't touch it, will have to live with it till mother nature removes.
Tom
AdamA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AdamA Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 7:54am
Don't feel too bad my FWD 8030 w/loader was movin mighty slow for 'bout an hour yesterday!! (your only stuck if you have too get pulled out!!!)
57'D-17,78'185,83'6080,76'7040,84'8030 FWA.02'Dodge cummins
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 8:01am
I Have an International Model 70 blower on one of my WD 45s its a 78" blower hooked to the three point. works very well, even blowing plow packed edges of the road back. I need to use brakes for steering though since the front end comes up if you move foward. I got it stuck yesterday blowing the driveway back only the cab and muffler were above the snow. I was still moving but could not get back out of the ditch. My wife pulled me out .
KC-WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KC-WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 8:05am
My wd45 did pretty good. I went ahead and put on the tire chains before the snow hit.
NEJim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEJim Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 8:17am
I learned years ago the tire chains are a must on the WD or WD45.  I put them on just ahead of the first snow and take them off in spring..
Mark/Ks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark/Ks Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 8:41am
I got mine stuck also,  Was moving some 5 ft drifts,  but under it all was Ice,,  and then lost all traction..  Probably will be stuck till some warmer weather comes along..
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 8:51am
Tire chains, aren't they just great!
8fan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8fan Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 11:30am
Look at the pictures I put up right after your post. I called it Blizzard 07 I think. Wd with a blower. Snow higher than the rear tires in spots. Works like a charm. Never be without it now.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 11:31am
Until a chain snags the fender and then its O****! Pa tore one off an unstyled WC back in '59 while hauling manure out in a spreader... Lucky some 4 year old wasn't sitten on it and hanging on that evening. Stay safe around chains.
jhanson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhanson Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 12:08pm
Forget the chains, it's time to get out of here
JohnThomas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnThomas Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 1:23pm
I used this setup for abt 13 years ..2 sacks of hard crete on front..no chains...did 10 driveways in neighborhood under contract with it. Loaded tires...if slip a bit just raise blower a tad ..second pass clean it up. We averaged 120 to 200 inches of snow those years too. Those bank cutters were always working the last month of winter..often snow falling over top of blower even.
I've posted this before, I know but  the question was asked.
Life is short...Make haste to be kind
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 6:25pm
Here is My WD 45 with blower. I'll never get an action shot. My wife won't come out and take one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 6:31pm
And the other WD45 with Erskine pull type. this works great for the road  just drive through and blow it into the woods.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 6:37pm
Where did you get the cab for the first pic?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 6:47pm
I bought it from the same guy I got the tractor from. Its from a garden tractor. just Angle iron welded between the front and back. I threw away the ripped vinal side doors and installed plexi windows. and filled from the window down with light steel. I just remove the tool box and 2 fenderbolts on each side disconnect one wire and lift it off. only takes 20 minutes to remove or install.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 7:18pm
I moved a lot of snow yesterday with a WD45 and 6' blade. Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote KC/WD Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 7:41pm
That's funny JHanson!!!
Good info here AC family, someone please give me a brand of a snowblower so I can do some research.
KC
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 7:49pm
I have an eight foot Farm King  Three point  snowblower.. Will go through anything .. i think a little too heavy for your WD
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 8:23pm
We were running 2 tractors with blades and one tractor and bucket trying to get the driveway and road cleared. It takes our grader operator days to show up sometimes.
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 8:43pm
Please forgive me for this dumb question but do you back in to the snow with a snow blower on a tractor? I've never laid eyes on one. I was just looking at the pics and wondered.  We have enough snow to use one this time but it's so stiff my bronco just rides on top.
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 9:12pm
Thad .. not a dumb question ..mine fits on the back of a three point tractor .. 6060 used to work .. on it when i had it but its more fun in a cab tractor .. The county has a 10 foot mounted on the front of an Oskosh truck ..
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 9:14pm
Yup.You gotta turn sideways and drive backwards.You learn to pay attention to wind direction and chute direction but I still prefer it to a blade or bucket.It's MUCH quicker and you don't have huge piles next to your drive to catch the next snow storm.The down side is it throws rocks (or anything else) where ever you aim it.The wife don't like rocks in the yard....oh well!
