What's your favorite engine heater
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Topic: What's your favorite engine heater
    Posted: 02 Feb 2011 at 10:45pm
for a WD45?  Temp in single digits today, went out to start the 45, and it just groaned.  Going to have some type of heater for next round of cold/snow.  I'm thinking of a frost plug heater, but maybe there is something that works better. (tractor sits in a shed with one side open, so it's like being outside, but protected from rain, etc.)
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 12:23am
The old fashioned way:
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 12:25am
Note the card board LOL
German Shepherd dad
#WD234847
#WD88193
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 12:38am
I don't think that is going to help get it started in cold weather, might help keep you going in cold weather.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 12:54am
For getting it started? Ether, hand crank, foot clutch lock. make friends with it.
Edited by AC WD45 - 03 Feb 2011 at 12:55am
German Shepherd dad
#WD234847
#WD88193
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 1:41am
block heater works the best i think!
Gary in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 5:55am
How do you install a block heater, or frost plug on a WD?
I would think a tank or hose heater (CATS)? use heater hose or lower radiator hose?
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 6:19am
No freeze plugs in WC-D17.Takes a tank heater and some engineereing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 6:44am
How about using an infrared light bulb as a heater? Like the ones for keeping chickens or french fries hot ?
Placed under the tractor, it should heat up the engine not the air ?
No risk of 'frost plug' problems.....especially in this weather !
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 7:02am
My favorite is a nice warm spring breeze maybe in May.
Wink
I am a Russian Bot
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 7:07am
Salmander heater and tarp!
wf32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wf32 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 7:08am
cheap and easy heater is a magnetic heater and can move to different tractors as needed
Phil
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 7:12am
I have always trusted the steel trouble light with a 100 watt bulb.  I also have a dipstick heater that worked great in a pickup I had once.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 7:16am
Get a battery maintainer.  If the battery has a full charge it will crank.  I have them on everything that's not used on a regular basis.  The batteries will also last longer if kept charged.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 7:49am
Hook A tank heater into the block drain donw by the carb. run the return hose up to the plug in the left side of the water pump. only takes a few minutes to install. put a street L in the block and the barbed fitting into it. This way you won't have a kinked hose.  I installed mine last winter when it was -20 F. I also have a tarp wrapped all the way around the engine. It started without it but you couldn't use it for 30 minutes. With the block heater plugged it about 30 minutes earler I can start and use it by the time I get the extension cord out of the way.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 8:11am
Magnetic heater stuck on pan, tractor out of cold wind, warm oil, engine will crank better, and if all is tuned fire in 2-3 seconds, ready to work.
MNfarmerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNfarmerAC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 8:54am
I started my 170 at -15 one morning and that was after being town to -30 the night before with no heater.  It has a new battery in it and I rebuilt the carb.  Had to crank it a few times on full choke but she eventually took off.  I would check the battery and make sure everything else is up to par... it should start.  Mine sits under a roof but is open on two sides too.
Brandon
1974 185
1977 185
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 9:43am
0W-20 Mobil 1 oil in it and no heaters are needed. The CA starts easily and oil pressure builds quickly with Mobil 1.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 10:07am
Hear here on the Mobil 1, using 10/30 here in winter,20/50 racing formula hot months
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 8:59pm
on all of our 45,s on the farm in indiana,we had heaters installed in the drain ports of the block.it had an electric motor type pump that kept the water at about 70-80 degrees when plugged in on shut down.definitly need on on the 45 diesel
