setting up a plow
allis restorer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis restorer Quote  Post ReplyReply Direct Link To This Post Topic: setting up a plow
    Posted: 01 Feb 2011 at 2:51pm
i have a 2 bottom plow for a Allis CA, and we converted it to a 3 point, what should the distance be from the inside of the rear tire to the point of the first plow point? any help would be appreciated, thanks
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2011 at 2:54pm
The distance from the inside of the tire to the first plow bottom should be the same as the distance between the two bottoms
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis restorer Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2011 at 2:58pm
ok thanks, i know its a little early to start thinking about plowing but i was just thinking about it, so i can be ready when the time comes
Robert Mull Georgia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robert Mull Georgia Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2011 at 6:47am
Usually on tractors like the CA, B, C using a two bottom plow the wheels are closed in all the way.
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2011 at 9:35am
Allis Res - Here is a picture that may help you with adjustments
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis restorer Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2011 at 3:34pm
thanks for your help
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2011 at 5:39pm
I noticed that there is going to be a "seminar" at the Hutchinson show this year on setting up a plow. Isn't it also a GOTO this year? Sounds like this would be a show not to miss...
gold642 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gold642 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2011 at 5:58pm
Are you using 12 inch, 14inch or 16 inch plows? Inside right rear tire to first point  should be the same distance as the plow width i.e. 12 inches for a 12 inch bottom. Remember you want your right tire  at plow depth and your left tire is at top of dirt. To achieve this, First place the tractor and mounted plow on a flat concrete floor or driveway.  To set your plow, if you want to plow 6 inches deep,place a 6 inch block under your left rear tire. Use a 5 inch block to set 5 inches deep.   With the lift handle down .Adjust your plow so both bottoms are sitting flat on the floor both directions. This should get you every close to being adjusted. After you shine the bottoms up . you might want to make fine adjustments in the field.
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2011 at 7:23pm
   To add to gold642's comment, the front wheels need to be blocked up to, if it is a narrow front. Wide front just block the left front.
http://www.rumelyallis.com
