D19 Distributor shaft and gear replacement parts
David(Stockbridge)MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David(Stockbridge)MI Quote  Post ReplyReply Direct Link To This Post Topic: D19 Distributor shaft and gear replacement parts
    Posted: 31 Jan 2011 at 6:16pm
Have customer looking for gear and shaft for D19 Distributor that drives the tachometer cable, I know they are GM parts. Does anyone have the part numbers and where I can find them? THANKS David
All "NEW" Web Site http://www.djstractorparts.com
2035,A,U,UC,WF unstyled,WF styled,WC High Crop (cane),RC,B,IB,C,CA,WD,WD45,G,D10,D12,D14,D15,D15 II,D17,D19,WC styled,WC unstyled H3 crawler
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2011 at 7:30pm
some people believe it is the same as some of the mid 60"s corvette drives, but the corvette one is about 0.060" smaller in diameter and then strips out the tractor distributor gear.. That is what I found out. if you find one that works out let us know.
Matt
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2011 at 9:39pm
Matt and I have had oppisate experiances with the 'Vette gears. We have the aftermarket gear sold for 62-70s Corvette in our D-19. Besides the obvious wear in the old one the 'vette part measured with in a couple thou of the one that was in it, was it original? who knows?  All I know is  we removed the distributor  so we could check things out thoroughly, installed the gear and it ran as smooth as glass in the distributor machine. Ours it is still running the tach a year later,maybe the only one I dont know??  Worn shaft bushings will effect the mesh as will the brass bushing that the gear runs through. It is also available along with the trust button all as a kit or as individual pieces. Search "corvette tach drive gear" on Ebay. We bought from Virginia Vettes, darned nice people to deal with.
Edited by Butch(OH) - 31 Jan 2011 at 9:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2011 at 9:42pm
goof up,sorry
Edited by Butch(OH) - 31 Jan 2011 at 9:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2011 at 9:43pm
another goof up, sorry
Post Options Post Options   Thanks (0) Thanks(0)   Quote David(Stockbridge)MI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2011 at 7:45am
THANKS Matt & Butch. Found some kit on Ebay and ordered a few set to take to shows and put on our web site. www.djstractorparts.intuitwebsites.com
Austin(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2011 at 8:39am
Did that with our D-19 as well. It worked for a while then stopped. Here to find out that the gear on the distributor shaft is chewed up really bad. need to replace that shaft on there in order for it to work properly. Otherwise the vette one should work.
"Better By Design"
Post Options Post Options   Thanks (0) Thanks(0)   Quote David(Stockbridge)MI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2011 at 5:27pm
Austin, where did you get a replacement shaft? If you don't mind me asking.
 ALSO YOUR MAIL BOX IS FULLLLLLLLLLLLLLL
