HD5G counterweights
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Topic: HD5G counterweights
    Posted: 31 Jan 2011 at 1:34pm
Pictures of counterweights on HD5G of 3 views of mine Notice inside weight is cut different and is thicker that outside one . also on back view one can see the AC name and HD5 cast into center of weight. On machine I seen in Iowa it has a logo in that position of AC
 Also it shows how i welded the build up of pads by adding 2 pieces or rebar to pad on front and rear grouser section.
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2011 at 8:01pm
Coke: Awesome shots of the counterweights. Appreciate you posting them.
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2011 at 4:40am
the counterweights i have look twice as thick from memory but we only ever had one on at a time. once the snow melts, i will post some pics. mine also has the ac logo in it.
