D10 series III tach
Thomas-NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thomas-NC Quote  Post ReplyReply Direct Link To This Post Topic: D10 series III tach
    Posted: 31 Jan 2011 at 10:39am
Can anyone tell me if or why a D14 tach will not work on a series III D10 with range trans?
Thanks for any help.
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2011 at 10:43am
I don't know, maybe gear ratio or RPM difference?
I just bought one for the D10 - D12 from Tonys tractors, very nice.
Bill B
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2011 at 10:57am
The RPM will indicate the same and be correct,  the MPH in each gear will be different.
If that is not a requirement, no problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thomas-NC Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2011 at 12:12pm
Becker,  The one Tony`s has is for D10-D12 up to serial 9000 series II.  I have the series III with Hi-LO trans which uses a different tach.
Joe,  I was thinking it would work, the mph might be off a little, not important,  just want to make sure the rotation of the cable was the same.  I think the face of the tach looks nearly the same.
Chad(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2011 at 12:44pm
 Not sure if it would  work, but the D-10 & 12 series one & 2 have different faces for the 4 speed VS 8 range tranny.
Edited by Chad(WI) - 31 Jan 2011 at 12:51pm
David(Stockbridge)MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David(Stockbridge)MI Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2011 at 5:55pm
We sell the one for the early D10 & D12 which comes with the bracket. They do not make one for the later series III with range transmission. I have used the D14 D15 Tach on my D10 & D12 which have the range trans and the work just fine. You will have to make your own bracket, but not a big deal. The cable attaches same as the D14 / D15 and they share the same 149 cu in engine, so RPM is the same. Ground speed may be off a little, but then again changing tires sizes will change it also. Sold this setup to a dozen customers and all were happy. Best of all the D14/D15 tach sells for only $75.00 verses the early D10 / D12 4 speed tach which is around $180.00  Also have the tach cables if anyone is interested.  David    www.djstractorparts.intuitwebsites.com
All "NEW" Web Site http://www.djstractorparts.com
2035,A,U,UC,WF unstyled,WF styled,WC High Crop (cane),RC,B,IB,C,CA,WD,WD45,G,D10,D12,D14,D15,D15 II,D17,D19,WC styled,WC unstyled H3 crawler
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thomas-NC Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2011 at 6:59pm
Thanks for the help David.  Sounds like the way to go.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2011 at 7:50pm
  we have mtg. brackets + tachs for the d-10 -12 tractors   also d-14-1 is your choice????  1-800-254-3116
This page was generated in 1.026 seconds.
