5020 ALLIS WHAT ARE THEY LIKE?
cdreb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cdreb Quote  Post ReplyReply Direct Link To This Post Topic: 5020 ALLIS WHAT ARE THEY LIKE?
    Posted: 31 Jan 2011 at 6:42am
I AM GOING TO BUY A 5020 FOR SMALL JOBS. WHAT ARE GOODS AND BADS ON THESE TRACTORS ?
Lyle124 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lyle124 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2011 at 7:36am
I've got a 5020 and a 60" belly mower, a 60" tiller and a 60" flail mower for it and they work just fine but it's a little light in the front end needs some weight. The only problem i've had is the radiator getting limed up and had to be rodded out.
5040 Bad Boy Mower
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2011 at 9:24am
I have a 5030 which is very similar and have found it to be a great little tractor - my wife loves it. I have to agree - they are light in the front and I have added some weight that has helped a lot. Very handy, and have had little problem -- just goes and goes! The early models have 4 forward speeds with a high / low range for 8 speeds. The later models have a high/ med / low range for 12 speeds. The low is really low. --- but have used it bush hogging some hilly trails in our woods.
niel ev View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote niel ev Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2011 at 11:21am
We have a 5020 and 5030 and the only thing that we find wrong with them is letting the little nephew run them out of fuel pain to get them primed up again Niel
ac.d17iv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac.d17iv Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2011 at 12:08pm
Does the high/low range allow you to shift on the fly...like the D series?  I've always thought they were neat compact tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2011 at 12:14pm
No - the hi / low range does not allow you to shift on the fly.  It's like a transfer case in a truck ---- put it in the range you want to operate in, then you use the gear shifter to use the four speeds in that range.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cdreb Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2011 at 12:59pm
thanks everyone...
Allen Dilg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2011 at 3:58pm
   Hello cdreb   There is a differental lock by right heel,  great for rototiller, have a 6' AC snow blade with box scraper works good
kip in cny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kip in cny Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2011 at 6:27pm
I have a 5020 I use it with a 5ft finish mower,5 back blade,5ft tiller,5 ft disk,5ft brush hog.  Its great on fuel I had to add about 100lbs of weight to the frount.  Its a littel hard to find parts for. Like it was said above never let it run out of fuel and always fill the fuel filter when changing them they are hard to prime.  The only thing I hate is its too fast in reverse high range.    But their only as good as you treat them
160 CA 920diesel 5020 HD-3
This page was generated in 0.083 seconds.
