mags advice
Tim in arkansas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim in arkansas Quote  Post ReplyReply Direct Link To This Post Topic: mags advice
    Posted: 30 Jan 2011 at 8:57pm
 Ok guys i have a question  I am getting no spark from  my 1940 B  I put new plugs in it  also on my 1938 B the mag is a model J   with a number 4b16a on it  now on the 1940 B it has mag k46 on it.  the caps are different on both on them   my main question is how can one check to see if a mag is in need of repair and where to get one repaired at thanks Tim
Allis Chalmers fan from Arkansas
RyanTN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RyanTN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 9:47pm
Tim, i will take a stab at answering your questions, but Steve at B&B custom circuits is the forum expert here when it comes to magnetos.  He rebuilt my first one, before I got comfortable working on them myself.  I was very pleased with how it turned out.  Sandy Lake Implement also sells exchange magnetos or will rebuild yours.  Both of their info is on the "parts etc" page which has a link on the top right.
Now here is a link that will show you how to test the spark on your mag and time it to your engine: http://www.worldpath.net/~thompson/acb/magtiming/magtiming.htm
Here is a link that will break down the different codes for your FM Mag:
I am either not understanding or not familiar with the "K46" you had listed.  Are they both FM mags?  Some wicos mags are out there and some early FM mags had a different cap and mounting style...Here a picture is worth a thousand words.  Again, I may not just be knowledgeable on the K46.
If you decide that you have no spark and want to investigate yourself, you MIGHT have success just cleaning everything up.  The last one I did for my IB just needed to be cleaned up and new points installed.  Of course getting the ants nest out if it helped too.
If you are certain that it is a FM J magneto, I have a couple of .pdf files that are copies of factory service manuals.  Here is a link for a real detailed service procedure for the FM J.    http://www204.pair.com/bbg46/FM%20Mag%20Manual/Magneto%20Service%20Practices(49-64).pdf
 Hope this helps.  Ryan
Edited by RyanTN - 30 Jan 2011 at 9:58pm
This page was generated in 0.143 seconds.
