AC 185 rear end noise
Big Al 485 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Al 485 Quote  Post ReplyReply Direct Link To This Post Topic: AC 185 rear end noise
    Posted: 30 Jan 2011 at 5:28pm
I have a 1977 AC 185. I'm hearing a whining noise in 4th high gear while running down the road. The noise seems to be coming from the rear end/ axel. Does anyone know what this could be? Such as a bearing or a worn gear?  It only does it in high gear at high speeds.
kip in cny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kip in cny Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 5:37pm
have you checked your tranny oil level ?  If thats not it I would start looking into the bearings
160 CA 920diesel 5020 HD-3
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 5:45pm
Never seen one that didn't have some kind of whine in road gear. You just buy this tractor??? or have you owned it for years and now it is worse than it used to be???
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 5:59pm
They all have bad gear noise !!! Grinds and growls
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 6:01pm
Not much experience with this but I got one with less than 1400 hours I just got in 2010, it whines in high too, hoping it is normal for these.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Al 485 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 6:08pm
tranny oil is good, i think you are right about the bearing i think its an axel bearing or something.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Al 485 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 6:10pm
i bought the tractor about a year ago, and it has done it ever since i got it. i wouldnt say it hasnt gotten any worse.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 6:28pm
Have you also checked the gear oil level in the final drives?  Fill plugs (no drain plugs) are on the inside of of each of the final drive oil pans.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
wheatbreeder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheatbreeder Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 6:38pm
do a road test drive it down the road for several miles with a load behind it high gear
Morley
Farm stuff 8050,6690,175,F2,5050,WD
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Al 485 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 6:39pm
Yes, those are full too. It's funny, it does not do it all of the time, it is louder  if you are going up a hill, and going down one too. On level ground it seems to be the quitest.
Thanks to all for your help !
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 6:53pm
Sounds kind of normal.
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 6:55pm
My 185 was almost new when I brought and it has always whined in 4th gear.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 6:58pm
Was running the 175 down the road yesterday and I was hearing the same kinda noises. Reminds me of the D15, I drove myself nuts checking fluids, etc, all were fine. I'm learning to keep ears open for new noises, and not worry about normal growling, whining taht seems to be built into these machines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheatbreeder Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 7:01pm
you need to try it with a load on it
Morley
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 8:00pm
My One-Eighty sounds the same way.  Mike
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
Hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunter Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 8:04pm
lol my 185 does the same thing but i have not noticed it lately i guess cause i am so used to it. but its a very dependable tractor. the best on our farm and has anybody had problems with those ear things on the power adjust rims we have replaced two on this tractor last year and are having to replace them again along with the old ones but the other side is fine. any suggestions on what could be the problem on why this is happening and they are also always coming loose after we tighten them.
bwp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bwp Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2011 at 12:23am
A friend's D19 has always made a howl or rattle noise in high 4th gear as long as he can remember, and so does mine. Both are used for completely different work, one used hard and the other not so hard. Only ever noisy in high 4th.
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2011 at 7:04am
I have run numerous D-17's, 190's, 180/185's and 200's.  They all whine , some more than others.
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2011 at 7:52am
Back many years ago when the old cars had a whiney  rear end they would put in a couple bananas!!
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2011 at 8:42am
There is a guy by us that would buy old tractors at auctions and he would put everything from sawdust to bananas!He had auctions but he would run everybody up so everybody hated him!LOL
This page was generated in 0.308 seconds.
