temp gauge on Model B
Scott in MA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott in MA Quote  Post ReplyReply Direct Link To This Post Topic: temp gauge on Model B
    Posted: 28 Jan 2011 at 8:50pm
I pulled the temperature gauge from my B because even though it still works, the face is unreadable. I should mention that it looks like the previous owner replaced the radiator with an aftermarket one. I ordered a new gauge from Steiner, which won't come close to fitting. They have been very gracious throughout this, BTW. They say they have sold countless models of this temp gauge to B owners without any complaints. Does anyone know what I have and what I need. The threads are slightly different, in case you can't tell from the photos. The pretty gauge is the new Steiner unit, and the ugly one is what was on the tractor. I need to know what the original gauge is, so I get another. Thanks for any help!
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2011 at 9:03pm
The Steiner one looks like the "correct" one.....
Go on eBay and buy a used thermostat housing to replace yours... They probably re-tapped it when they put that one in that you had.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 2:57am
I agree with Glenn. The Steiner guage is correct. The old one probably  is an industrial application and has 1/2 inch pipe threads.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott in MA Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 5:50am
Thanks guys. What about the long copper/brass piece on the Steiner gauge that's not on the mystery gauge? Steiner suggested that the old gauge may have had the same feature and it's now stuck inside the radiator. I can't see it but I don't know if I'd be able to. Any thoughts?
SteveC(NS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC(NS) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 7:02am
Replacing the waterneck/thermostat housing will show you if there's something stuck in it and it won't matter 'cause putting the new one on will solve the problem.
Surely someone on here, closer than I am, has one they can sell you for a reasonable price.
