Pull-type combines, galvanized only?
Murph-NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Topic: Pull-type combines, galvanized only?
    Posted: 27 Jan 2011 at 7:42pm
Did AC or any other company sell a pull-type combine that was not painted, only galvanized steel like the Gleaners?  I've spotted one in a fence-row, but it's too far away to tell what it is.
'41 C w/Woods L503 mower, #3 mower, 2-way plows for C
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2011 at 8:43pm
I think the Gleaner pull types were galvanized
acd21man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2011 at 9:05pm
yes they were iv seen 1
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2011 at 9:13pm
When were the Gleaner pull-types built and how does that relate to when the All-Crops were built?  Thanks in advance.
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2011 at 9:22pm
Didn't JI Case build some many many years ago?
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2011 at 9:37pm
   Alot of the early combines were galvanized. Rumely, Avery, Baldwin, Deere, and Holt come to mind.
http://www.rumelyallis.com
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2011 at 9:37pm
I have seen other brands, there is one in the trees  a couple miles from me, I think it is IH but not sure, too much snow to look now. I think MM made galvanized too.
Dale-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale-OH Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2011 at 10:07pm
Gleaner pull types were built i know up into the mid 50's.  Compltly different than an AC, ill try to find a picture of one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2011 at 10:14pm
1927 Gleaner pull type. Has a Ford Model T engine on it.
Another
Edited by AllisChalmers37 - 27 Jan 2011 at 10:14pm
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2011 at 10:52pm
Most threshing machines were galvanized too. Depending on how well you can see it, it could also be a threshing machine.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2011 at 11:57pm
I think by the '30s most companies started using regular sheet metal and painting it company colors.  It seems like it would be cheaper to use galvanized metal rather then paint but the bean counters of the day may have thought different.  Plus if you painted it the company colors it looked like it belonged with the rest of the machinery sold by that company.  Gleaner, on the other hand was known for using galvanized metal from the beginning.
Allis Express participant
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2011 at 7:30am
The last Geaner pull-types, if I'm not mistaken, were the P80's built in 54' & 55' I think. Allis bought Gleaner in 55 and stopped all Gleaner pull-type production. My brother has a P80 with Allis-Chalmers decals. I've got to get pics up here of it sometime soon.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2011 at 7:50am
The one I've spotted is flat across the back like an All-Crop.  Maybe it is an All-Crop that's been outside so long the orange has worn off.
Chad (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2011 at 9:17am
I have it on good authority that some of the Roto-balers, combines, and pickers that were produced by Allis after WWII contained some aluminum sheets because it was easier to obtain after the war than sheet steel.  I had an early Roto-balers with aluminum hopper, and I have seen combines with aluminum sheets randomly assembled next to the steel sheets.  Maybe the "galvanized" pieces were actually aluminum?  Just a thought!
220 3-190XT 2-D19d D19g 5-D17 UC 3-WC 2-WD 3-WD45 CA C H3 7-AllCrops 14-plows 3-Gleaners Lawnmowers SC-equipment
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2011 at 8:02pm
Our 47or 48 model 60 was painted but the paint peeled of in big sheets and it was galvainsed under the paint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2011 at 8:25pm
I found an orange painted aluminum belt pulley that  fits my C & B.  Wondered what the story was on that.  Was on a farm with only an all crop,  no AC tractors, ever.
countryguy828 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote countryguy828 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 1:51am
I once read somewhere, probably here... that CA's came with aluminum belt pulleys
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 8:48am
I would think that painted combines have raw unfinished sheets of steel, not galvanized, under that paint. Cheeper to produce and paint sticks better if it's not painted.
Dusty
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 10:32am
Dusty
They were still painting the new Gleaners silver over galvanized metal last I checked. I haven't checked in almost ten years. You can paint galvanized metal if it's prepped right. It's not as hard to paint as aluminum.
Remember the old AMC cars that were galvanized and then painted. I think our old Beretta car may have had some galvanized parts and I'm pretty sure All Crops are galvanized under the paint.
Edited by Lonn - 29 Jan 2011 at 10:36am
Wink
I am a Russian Bot
Reeseholler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reeseholler Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 1:02pm
my ca has the aluminum pulley.
This page was generated in 0.359 seconds.
