190XT Tractor Fuel Problem
JRCSD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JRCSD Quote  Post ReplyReply Direct Link To This Post Topic: 190XT Tractor Fuel Problem
    Posted: 26 Jan 2011 at 10:21pm
I am having trouble reaching the second water/sediment bulb on the fuel tank it seems everything is in the way from Hydraulic lines to the three point hitch cylinder to the back tire. I can barley get one arm up in there and I believe the bulb is full like the first one was with rocks and gummy sediment. Anyways with this I was hoping for a new idea with out having to have the tire taken off to get to it. It also seems I can not remove the fuel tank with out taking off the sediment bulb because it will not clear. I may be going at this all wrong hoping someone out there can help! Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 10:31pm
You only need one of the two to make the tractor run. Be sure to leave out the screen this time of the year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JRCSD Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2011 at 9:10am
Just to let you know we got the problem fixed and we are off and running again. We had to take the left side wheel off to get to the first sediment bulb and the sediment bulb on the right side was pretty simple to get to. Both were full of small pebbles not allowing a good flow of fuel which is why it would run for a while then studder out. Anyways thanks for all your help. Hope to learn more from this forum I have been reading some of the posts and have learned some things about my 190XT that I did not know before.
