D12 Oil pump?
gary ny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gary ny Quote  Post ReplyReply Direct Link To This Post Topic: D12 Oil pump?
    Posted: 26 Jan 2011 at 7:33pm
I just went to drain the oil on a customers d12 and it just dripped out so I pushed my finger up through and felt a flat round plate up in there.It is a about 3 to 4 inchs from what I can feel .I was just wondering what the oil pump looks like on the early d12s .I thought that maybe it was  a trans.magnet at first but it does not feel magnetized .I can t think of what it could be other than a oil pump base
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 7:37pm
 to my knowledge the pump is mounted on the rear of engine   mght be the strainer????
Post Options Post Options   Thanks (0) Thanks(0)   Quote gary ny Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 7:49pm
the strainer is what I was thinking but I am not sure what they look like.It does not feel like the same as a B or C .It s going to have to come apart .I was just preparing myself  for the what could be's
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 8:43pm
The strainer is round, about 3-4" in diameter. About what you are describing.
They slide on the pick-up tube and are held on with a cotter pin. They are designed to float. solid on top with a brass screen on the bottom. Bob
