WD45 Snap Coupler Screw Rivets
jeh2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeh2001 Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Snap Coupler Screw Rivets
    Posted: 26 Jan 2011 at 11:17am
I'm stuck.  I'm rebuilding the 2 snap couplers on my WD45 lift arms.  Simple, right!?  HAH!  Two of the screw rivets are broken off.  These little things hold the springs that snap the coupler latch.  I've tried drilling, milling, and grinding the broken pieces out.  Very little success.  What are they made of, Kryptonite?  Any suggestions would be very appreciated.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 11:22am
I've got to do the same thing some day. I was thinking maybe heating to soften the rivets. They are very hard. Tried to drill them out once back in my high school days but not since. Too bad there isn't a place to exchange them for a rebuilt set. Does that give anyone here that may have mastered the removal of the rivets any ideas?
Edited by Lonn - 26 Jan 2011 at 11:23am
Wink
I am a Russian Bot
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 11:38am
I have done a couple sets, Heat them and let them cool, then they drill OK, also use the best drill bits you can find not the cheap ones.
start with 1/8" drill bit.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 12:08pm
When you get the 2 Rivets out of each 'Lift Arm Latch" you will need one of these kits  to make them like new again.
Gary
barky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote barky Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 12:24pm
Use a drill press and buy several bits I used IRWIN cobalt. You will suceed.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 12:32pm
Like Matt says, heat them red hot, let em cool, they will be soft and will drill ok.  Ive dont quite a few and thats the only way to go, absolutly no frustration this way!!!!  HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeh2001 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 4:56pm
You guys are great!  I heated them with an acetylene torched, cooled, then drilled using my drill press.  They came out easily, nothing special after I softened them.  I never would have thought about "unheat-treating" them!  Thanks.
NCAllisnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCAllisnut Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 8:16pm
I used 1/4-20 or 5/15 threaded studs to replace the rivet on a set I fixed.  Get the springs hooked, then thread on an acorn nut.
dannyraddatz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 8:25pm
I had to have a bolt removed a few years ago out of a front end with out damaging it, look for one of these in your neck of the woods.
Danny
Edited by dannyraddatz - 26 Jan 2011 at 8:25pm
Danny Raddatz
This page was generated in 0.250 seconds.
