B non pressurised radiator
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Topic: B non pressurised radiator
    Posted: 25 Jan 2011 at 4:47pm
Does anyone know what years they used the unpressureised radiator with the gas tank type cap on it, on the B?
Thanks, Bill B
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2011 at 7:45pm
1937-1942 used unpressurized radiator.
Actually, in 1942, at serial# 61223, they started using the pressurized version....
Only    178   1942 B's had a pressurized radiator....
john2189 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2011 at 10:59pm
what is the differance in the non pressure and pressure radiators?  I have a 42 serial 56xxx  and 45 and they look identical.  would it hurt if it had a pressure cap on a non pressure radiator ?
'41 Allis B
'45 Allis B
'49 Farmall Cub
'72 IH Cub
pumpkin man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkin man Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2011 at 11:27pm
 the filler neck is differnt [non pressure-the cap locks are on the inside of the  filler [like the gas tank] same type of cap but not vented [pressure type-cap locks are on the outside of the filler neck the cap has a spring and rubber seat  they come in psi. rateings. tractors look the same -radiators differnt
swit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote swit Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 7:31am
so what would be a all around thermatat to run in a b since mine never gets hot.maybe a 180
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkin man Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 10:40am
try one may be all right depends how hard you work it in hot weather rember its only a 2 gallon cooling sy,m.
This page was generated in 0.045 seconds.
