Recommend Good Tires for Loader |
rasman57
Topic: Recommend Good Tires for LoaderPosted: 25 Jan 2011 at 10:18am |
I need to replace front tires on a big bucket loader tractor. At least E rated or in the old days, 10-12 ply rated for sure. Original size was 7.50 x 16 and I just discovered that 11 inch wide pickup tires are too wide and rub against the spindle steer arms..of course. Any experience with brands or mfg recommendations good or bad. Seems hard to find a 16 inch less than 11 inches wide with a real load rating in my on line search so far.
john(MI)
Posted: 25 Jan 2011 at 10:32am |
Trailer tires?
Dans 7080
Posted: 25 Jan 2011 at 10:52am |
A 235-85-R16, has a width of 9.25" and a height of 31.75".
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42105 |
Posted: 25 Jan 2011 at 10:54am |
I used wagon float type tires on IH 460 Utility with Henry loader
On the 715B I have a Goodyear tire made for Industrial laoders , might try to look in dealer catalog and see whatthey have for TLB use.
Matt MN
Joined: 14 Sep 2009 Location: Silver lake MN Points: 1491 |
Posted: 25 Jan 2011 at 10:56am |
A 215-85-16 tire would work out also unless you are in soft ground. We have some 10ply 7.50-16 3 rib on the front of our loader tractor, but they were expensive..
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34435 |
Posted: 25 Jan 2011 at 11:36am |
Matt where did you get them? 8 ply were from 80-130, couldn't find any 10 ply. My tires break out in the side wall before the tread facing is worn down very much..and I keep them up over 45-50+# pressure. Use to run at 35-40 but didn't hold up at that pressure either.
Matt MN
Posted: 25 Jan 2011 at 11:46am |
they were from the local Cenex store, I believe they were almost $200 each with the tube.
Rawleigh
Joined: 14 Sep 2009 Location: White Stone, VA Points: 421 |
Posted: 25 Jan 2011 at 4:12pm |
Used 18 ply aircraft tire $48.00 plus shipping. New $108.00. new on rim $154.00
http://www.noflats.com/tractorfronts.htm |
