tire chains
TerryMtAuburnIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TerryMtAuburnIA Quote  Post ReplyReply Direct Link To This Post Topic: tire chains
    Posted: 25 Jan 2011 at 8:48am
hello. can anybody tell how long the chains have to be for 28 in. tires on my wd. thank you.
SeanD17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SeanD17 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2011 at 9:21am
I can't off the top of my head, but I found out a couple of years ago that any place that sells tire chains has a chart and can quickly tell you anything you'd ever want to know, length-width-number of cross bars-etc.
D14 N.F., Series lll D17 N.F, 3 Bottom Snap Coupler Plow, 4 Bottom Slat Snap Coupler Plow.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2011 at 10:58am
It all depends on the tire size. 13.6-28 takes a different size chain then a 14.9-28.
if you find some to fit a 14.9-28 they will work on a 13.6-28 but might be really loose fitting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TerryMtAuburnIA Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 9:59am
i was wondering how long 14.9 chains would have to be. i am makeing 2 24in. chains in to 28in. chains. does anybody no how long thay have to be thank you.
JM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JM Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 4:56pm
Try tire chains .com
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 6:24pm
Pic a spot on the sidewall where you want the side chain to ride and then measure across to get diameter, multiply by 3.14 should be circumference, am I correct? then add a few in.  measure cross chains to make sure they are long enough.  HTH Mark
This page was generated in 0.135 seconds.
