mounting ca rear weight???
caRon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Topic: mounting ca rear weight???
    Posted: 24 Jan 2011 at 4:04pm
Can't get to the tractor to measure, does anyone recall the correct size ( 3/4 I assume) and length carriage bolt used to mount rear weights on a ca. Can't find hardened ones, are the standard carriage bolts strong enough? Anyone just use regular 8 grade bolts? Thanks Ron
CA Tractor
mnoonan-NEWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2011 at 4:53pm
Ron,
I have one set of weights attached w/ regular carriage bolts purchased from Fleet Farm. (2) per weight. I presume they are grade 3. I believe they are either 3/4" x 3" or 3 1/2". I don't have the tractor here to measure. My other CA has (2) factory carriage bolts per weight held on wheel center with a cotter. The factory carriage bolt was drilled for a 3/16" cotter to be used as a retainer to hold bolt on the wheel center while you slid the weight on. That probably doesn't help much but best I can do for now.
Good luck,
Mike
AC CA, Ferguson TO-20, Ford NAA, M-M BG, AC #3 Mower, SC Plow, PH Digger, AC 720's with Ark 700 loader & Brantly Backhoe, "Mini B" w/flathead Ford V8
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2011 at 7:34pm
Ron,
Here is a picture of my restored CA with the rear weights. Note the cotter on the bolt holding the weight on. Also for figuring the bolt length, measure from one of the flat areas that touch the wheel center perpendicular to the flat where the washer bears then add about 1/4" thickness of the wheel center plus washer and nut.
Again,
Good luck,
Mike
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2011 at 7:43pm
I used (4) 3/4 X 3 1/2  carriage bolts on each wieght. then trimmed the little excess off each bolt. Some where out in the shed I have the original bolts with keeper holes drilled in the head. they only came two to a wheel and I wanted four.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2011 at 7:54pm
Hi Ron,
    I was told by others on here that regular carriage bolts are plenty strong.  The ones that I have are 3 1/2", but I couldn't find them at Farm & Fleet.  The biggest they had here were 1/2", not 3/4", which is what you need.  I had to go to Fasten-All.  Hope it helps, Ted
Reeseholler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reeseholler Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2011 at 8:24pm
Thanks for the replies and for the topic ron. I'll be putting mine on here in a couple of weeks. good information to know
DSpears N IL View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSpears N IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2011 at 8:28pm
Hi Ron and all
I have used the 3/4 X 4 grade 8 bolts for mounting my weights. I use a 3/4 coupling and a 2 inch bolt to fasten a second weight to each wheel and I use 4 bolts with flat washers on the back side of the wheel.
DeWayne
Edited by DSpears N IL - 25 Jan 2011 at 11:50am
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2011 at 9:11pm
The carriage bolts are threaded to the head, so I just use a jamb nut to hold it in place on the hub.
ALLIS EXPRESS!
This year:
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSpears N IL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2011 at 11:51am
Bump it up!
DeWayne
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2011 at 4:41pm
I likw DSpears idea for adding another weight
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2011 at 6:12pm
The following is from the parts book and this is my interpretation. It suggests when using 2 outside weights that the inner wheel weight be attached with 2 bolts (#70225325) and the outer weight be attached with 2 different bolts (#70915762). This I believe since there are only 4 holes in the weights. These bolt lengths are not identified in the Dealers Parts Catalog for Standard Parts form D-10. What do you guys think?
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2011 at 8:09pm
Thanks for all the replies and pics!!! Ron
CA Tractor
This page was generated in 0.127 seconds.
