clip or no clip on float needle ?
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Topic: clip or no clip on float needle ?
    Posted: 24 Jan 2011 at 1:37pm
My parts are on the way for the wd-45 that stalls under load. I am going to put a float needle and seat in as well. I read before not to use the supplied clip. Opinions. Thanks again for helping me out. Mike
patrickmull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2011 at 1:40pm
does this wd-45 have a paper filter mine would miss and stall i took it out and it fixed it
Good View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Good Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2011 at 1:59pm
I would think with the clip on, the weight of the float will help pull the needle down if it was wanting to stick any.
B212,716,two 314H's,WC,WD,D19,190XT
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2011 at 2:20pm
 Personaly Ive never seen a problem fixed by installing one
But neither have a seen a problem fixed by removing one.
Hows that for being wishy washy? LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2011 at 2:23pm
I would put the clip in if it were mine. That way you know for sure it's not going to stick.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2011 at 2:50pm
I can't remember the reason for no clip but like with most things there was one.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 6:02pm
I finally got to the cabin today to work on the wd-45. Off I went with my bag of parts. I had soaked the carb in solvent, new load valve and new float, needle and seat. I drained the tank and removed the sediment bowl assembly. Checked the tank. No rust as expected, one sliver of grass I think. Was going to run the tube into the tank but thought better of it. Put a screen in instead. No water in gas. Hooked everything up and started it. Ran terrible, could not adjust carb. Shut off and gas poured out the carb.  Took carb apart again and checked the float setting. What I ended up doing was reseting the float needle valve and bending the float a little. Seems to work ok after fine tuning the carb. Why does my float not want to shut off the gas? This has happened before. Sorry about the length but this what I did to my tractor. Plowed snow for an hour afterwords. Thanks again for all the help. When I get my C home I sure I will be begging for help again. Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 6:13pm
Gas pouring out with the engine not running problems could be: foreign object preventing the needle from closing on it's seat, a float that has fuel inside it or level adjusted too high, a float contacting the side of the bowl so it can't move and shut off the fuel flow. These are what comes to mind right off. There could be other things though. If it were mine, I'd get a new sediment bowl and make a new line from the bowl to the carb. My CA gave me a bunch of carb grief until I made a new line. Old crusty fuel deposits in the line kept clogging things up. If you know for certain the level is set correctly, make sure there isn't any gas inside it. If the float is full, it will sink.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 6:16pm
Its a new float and the gas had no junk whatsoever in it when I drained the tank. Can the float hang up on the side of the carb at all?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 6:27pm
If it were bent it could. Did you check the level when you put the float in, or did you just put it in there?
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 7:50pm
I checked the level with a 1/4 drill bit quite a few times. I never have had much luck with floats.
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 5:27am
Worked on a WC one time that had a float that the pontoons were sunk in (like you pinched in). Put a new float in and that cured it.
"Burgie"
bigallis1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigallis1 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 7:42am
I always use the clips supplied with the kits.
I believe they help keep the needle from sticking.
Setting the float level properly is critical also to preventing leaking.
Edited by bigallis1 - 30 Jan 2011 at 7:42am
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 10:17am
That munched float didn't survive water in the float bowl that froze.
Gerald J.
This page was generated in 0.223 seconds.
