Generator Power Steering Pump
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Topic: Generator Power Steering Pump
    Posted: 23 Jan 2011 at 7:36pm
The splines on my generator for the P/S pump are worn, but haven't stripped yet. It turns out the shafts on the generator and pump along with the coupler are hardened. The shafts are too small to cut a key way. The only thing my machinist was able to come up with is cut the splines off leaving the shaft on the generator and pump 1/4" hex. He would then make a new coupler and run a 1/4" broach through it to make the coupler.
What has anyone else done to fix this issue short of finding new old stock somewhere? My machinist thinks it would work since we really aren't reducing the shaft size, it's just the cost involved for doin only one. He says $200 to do just mine since a 1/4" broach isn't something he has alot of demand for. If there were other's in the same situation as me that were looking to fix stripped out splines, the cost would come down a bunch.
What do you guys think?
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2011 at 7:41pm
I stripped my coupling out and found that a new coupling would hold and drive the pump. The splines were much worse on the gen. side so I sqeezed a small amount of JB weld into the coupling to help take up the slop on the gen. side and left the pump side clean in case I have a need to dissasemble for some reason. New couplings are avaliable, but they are pricey. Not as pricey as you just described though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2011 at 7:46pm
That's good to know. I thought I had seen this come up before and parts were NLA. The splines are definitely much worse on the generator on mine.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2011 at 7:59pm
  answered in the classified this morning  we have new couplers available a tad longer than originals  have had them available yrs. now cheaper than agco 1-574-342-4545
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2011 at 6:47am
Looks like it's Norm to the rescue. I'll call later this morning. Thanks guys.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2011 at 11:06am
Norm to the rescue on this one. For those who don't know his couplers are a little longer than the originals to reach into non worn areas of the splines. He also tells me that if your pump gears are bad, he has a source to replace them with new.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2011 at 11:26am
I assume this is for a D15D and D17D. Nice to know this info
1968 D15D,1962 D19D
Good View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Good Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2011 at 12:51pm
Norm saved me with one also and saved me money over Agco.Mine was for a WD45 diesel generator. Raking hay was just not as fun without power steering.
B212,716,two 314H's,WC,WD,D19,190XT
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2011 at 2:25pm
Yep, anything that had the P/S pump mounted on the back of the generator. In my case series 1 D17D.
EdIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EdIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2011 at 8:55pm
The coupler and pump shaft were still available from AGCO 2 weeks ago.      Ed
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2011 at 9:06pm
I'm still kicking myself for selling a D17D generator and pump for $100 a few years back!  I could of at least got a nice thank you card from the buyer.....
ALLIS EXPRESS!
This year:
JOHN N/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JOHN N/IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2011 at 9:11pm
im still looking for one
simplexguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote simplexguy Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2011 at 9:27pm
I had a wd45 diesel with the power steering pump driven off of the generator. That shaft in the generator was the same as one from a 57 chevy power steering  generator, and an early Corvette w/ fuel injection. The early fuel injections were driven from the back of the generator just like the power steering. You might check that avenue as I believe they are made aftermarket
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2011 at 9:51pm
" if your pump gears are bad, he has a source to replace them with new" nice to know, Got an old pump with bad gears and could use a spline adapter...
 Many years ago made a mistake, had D17 diesel gen in for a rebuild, Fellow had new longer generators with spline end on it and mount that would fit pump...I didn't think I had enough hose to adapt longer gen but it would have worked. and would have had more output.
