7000 Starter
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Topic: 7000 Starter
    Posted: 23 Jan 2011 at 2:41pm
My 7000 with a Delco starter is starting to act like the Solenoid is sticking/not making good contact.  It will sometimes click, sometimes it will work, and sometimes it just does nothing.  Usually a couple good hits with a big screw driver handle fixes it, but my Dad called me today and said it was really getting temperamental.  I have had to take it off and tighten the nut on the copper strap that crosses from the solenoid to the starter, but last time, I couldn't really get it too tight, as the stud began to turn a little and I didn't want to mess it up.  I remember reading that there is a gear reduction starter that can replace the Delco and Lucas starters on these tractors that was much more reliable and spun the engine over faster.  Does anyone have any details like price, where to buy one, and a part number?  I may do that if it's not a simple fix on the current Delco.
Hurst
1979 Allis Chalmers 7000
5800 Hours
Steele View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steele Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2011 at 2:52pm
Sure it isn't your safety switch on the clutch.  Take a heavy wire and jump it to make sure that isn't your problem before you mess with the starter.  Mine has acked up at times.  I assume the 7000 has one like the other 7000 series.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2011 at 2:58pm
Safety switch is already bypassed...
Hurst
5800 Hours
Russ-neia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2011 at 3:12pm
The late 8010's used the reduction starter.  Look up the AGCO part number and go from there if that's what you want.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2011 at 3:57pm
Is the reduction starter preferred over the Delco?  I was thinking it was a Denso unit or that there was a Denso replacement for the 301 that was supposed to be top of the line?  Maybe I am thinking of something else.
Hurst
5800 Hours
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2011 at 5:15pm
think i've replaced the solenoid on my 7010 a couple 3 times. it's a dealer item only, i bought 2 last time and put one on the shelf.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2011 at 6:00pm
Thanks for the tip.  I may have to see about getting one of those from the local... Cat/Challenger dealer.  Sure miss the old Allis dealers that we used to have around here.
Hurst
5800 Hours
Andrew(southernIL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew(southernIL) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2011 at 10:28pm
Dose sound like your solenoid but something I had trouble with was the PTO safety switch that is located behind the batteries, its just like the clutch switch.
If fishing is a sport your looking at an athlete
Slade (TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slade (TN) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2011 at 8:37am
Hurst I have a denso starter that we put on a 185 that we rebuilt to start it the first few times while we were waiting on the customers lucas to come back from the shop.....It was originally intended for the pulling tractor but never made it.  79003057 is the part #.  $300 + freight.  615-542-6999 Slade
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slade (TN) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2011 at 8:39am
meant to add, this starter might have started that tractor 5 times, other than that it was brand new from AGCO.....save you some money!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2011 at 9:23am
Slade, I'm going to first try the solenoid and see if that fixes it.  If it's not the solenoid, I'll get in touch with you about a new starter.
Hurst
5800 Hours
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2011 at 9:33am
My 7010 P/S has the Nipindenso. It was acting like your was, the starter man in town went thru it for $42 and it works great now.
"Burgie"
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2011 at 9:35am
I found out the hard way as usual , make sure you have big battery power to it , or it,ll burn it up ; thats what the starter fix-it shop said !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2011 at 1:56pm
It has 2 group 31s on it that are a year old, so battery power shouldn't be a problem.  Talked to my Dad this morning and he said it fired right up today, so I'm guessing the contacts in the solenoid are about gone?
Hurst
5800 Hours
