governor weight
Red View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Quote  Post ReplyReply Direct Link To This Post Topic: governor weight
    Posted: 23 Jan 2011 at 2:23pm
Is it possible to replace a weight by removing the small governor cover?   If the timing cover has to come off what is the easiest way to do get it off?  Thanks      Forgot to say this is a D 17.
Edited by Red - 23 Jan 2011 at 2:46pm
Chris (swIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2011 at 3:24pm
No, and no the timing cover does not have to come off to replace the govenor weights. Just pull the govenor/distributor assembly. 3 bolts and it will come out to the back.
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2011 at 4:56pm
Be VERY carefull removing the little clips that hold the pins. They like to go ZIIINNNNGGGGG!! to no mans land.Just as bad installing.
bill2260 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bill2260 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2011 at 5:06pm
mark which way the rotor button is pointing before you pull distributor makes it easier to get back in time. Bill
Red View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2011 at 7:23pm
Thanks.   Just what I needed to know.   Should have this thing going again if I can get parts tomarrow.
This page was generated in 0.044 seconds.
