CA surging "PROBLEM SOLVED!'
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Topic: CA surging "PROBLEM SOLVED!'
    Posted: 23 Jan 2011 at 9:20am
First off, thanks to all for the input. Burgie, RSponenburg and Steve M hit it right on the head, throttle shaft seal. Since I had changed carbs just two days ago I thought the throttle shaft seal couldn't be the problem. But I went and looked at the carb I took off and sure enough that one had play in the shaft also. I guess the method I used for checking for leaks didn't work. Anyway, I found a seal leftover from a previous kit, put the carb back on, removed my "quick fix" and gave it a try. It started fine so I took it for a test run pushing a little snow on the driveway. It is back to running the way it should. Thanks again guys.
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2011 at 9:27am
You are welcome.
"Burgie"
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2011 at 1:54pm
Always nice to hear the fix.
RSponenberg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RSponenberg Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2011 at 3:04pm
Glad to help....
