Need some snowblower help
Mercury45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mercury45 Quote  Post ReplyReply Direct Link To This Post Topic: Need some snowblower help
    Posted: 22 Jan 2011 at 4:06pm
Hello all... I am new here and I plan on sticking around as long as I can get my allisChalmers sno bee 7 cracking again...
here are some pics
http://s376.photobucket.com/albums/oo206/mercury45/Snobee%20Snowblower/
Also a video....   http://www.youtube.com/watch?v=MUHtkLOmugc
The parts i neeeed is the large impeller / auger pully (9 inch sheve) with 7/8" hold and keyway  and I also need the bearing for the back of the impeller the one that was supposed to be there was totally gone
does anybody know where to get these things... anybody have a manual with part numbers they can check for me,  ill pay pal you some money for checking into it if i have to
thanks in advance
kenny
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mercury45 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 4:10pm
Sorry gang,  I forgot to put the numbers in here
I know its an older allischamlers sno bee 7  (7 hp)
model - sno bee
Serial # 7-001356
thanks,  Kenny
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 4:15pm
Unsure of your location .. many farm supply stores cary sheaves (pulleys) with weld in center that is pre-bored to shaft size you need . As for bearing you may be able to use a pillow block flange mount bearing also that you can get at same store.
kip in cny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kip in cny Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 4:17pm
the pulley and key stock and bearing you should be able to get them from the local farm store the impeller that may be tricky
160 CA 920diesel 5020 HD-3
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mercury45 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 4:44pm
i just need the pulley and the impeller bearing,  nothing else....   in my pics i still have the flange for the impeller bearingmaybe i should look for a bearing that fits in it?  I'm very new at all this please pardon my ignorance....
I am in NJ  when you say farm store, I tried a loca... power equipment place but he did not  have what i needed....   ill try tractor supply maybe but i do not know if they will have it either....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 8:11pm
Your pictures or video do not come up for me . TSC might have it or a bearing supply house , industrial supply place would have it also can try WW Granger or McMaster Carr, both should have a online catalog you can check.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mercury45 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 8:27pm
thanks coke----  those websites work for me i just copy n paste to url bar
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 9:35pm
dang brouser Bing or whatever would not work with it .. got it now.
Sheave should be no problen finding as it is stamped steel and most farm stores will have them and the weld in center. The bearing are what are called light duty with pressed steel flange , if the steel isnt worn then the incert (bearing assembly) can just be replaced but full 3 bolt unit might be best to buy. As they are set screw lick to shaft it looks like might want to go back to same , but other style locking divices are also out there.
 That is one problem with the light duty bearings they can't be serviced , just replaced. Unsure if you have room but might look at another type bearing housing that allows greasing bearings.
Edited by Coke-in-MN - 22 Jan 2011 at 9:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mercury45 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 9:48pm
thanks coke ill take a look... seems most of the bearings are 2 or 4 bolt, but ill keep looking for 3 bolt....  as for serviceable - not a big deal... if it lasted 40 years the first time, if i get 2 years out of it ill be overjoyed.
thanks - kenny
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 10:14pm
At a bearing house or even farm store many times they have just the insert, try McMaster Carr also  and I just looked quick  but in some cases the bearing can be removed from a 2 or 4 bolt flange and put into other housing like yours.
