6080 balancing
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: 6080 balancing
    Posted: 21 Jan 2011 at 7:33pm
How much weight do you need on the rear of a 6080 to get traction ? Its got 18.4-34 rears full of fluid,600 lbs of dry weight and still spins helplessly some times ; an old AC dealer told me when they came out ALLIS wasnt quite done with these unbalanced  FIAT machines ; he was 100 % right
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 7:37pm
Its been a bad day , blading, pushing snow with this thing  !!!!!!
D17 owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17 owner Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 8:20pm
Dose it have a loader on it?
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 9:12pm
Chain er up!
ALLIS EXPRESS!
This year:
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 9:20pm
Yer kidding yerself without chains.
rrhead(SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrhead(SD) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 10:12pm
Gotta have the chains! rrhead(SD)
Steele View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steele Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 8:07am
Chains will make it almost as good as a MFWD tractor.  Used a 6080 with loader and chains to feed beef cows in not so flat terrain here in Western Wisconsin for 10+years until finally purchased a 6080 with MFWD.  It does do a little better than the 2wd with chains.  NEED CHAINS!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 9:55am
...and if you run chains,don't ABUSE them!Excessive spinning,high speed road travel,etc.You can tear them up and then they can tear you up!Sometimes you have to abuse them a little but just use some common sense.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 11:50am
I,d have to run chains all year long , its that way on green grass too !!!
This page was generated in 0.590 seconds.
