Question 5bolt to 6bolt Hub Conversion
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Topic: Question 5bolt to 6bolt Hub Conversion
    Posted: 21 Jan 2011 at 12:56pm
Anyone know if the hubs off a smaller AC combine will switch over onto the WD-45 front spindles/axles to move you from a 5bolt to a 6bolt hub & Rim.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 1:10pm
I don't have the answer but the later D-15's and D-17's had 6 bolt hubs.
Maybe a 6 bolt from a D-15 will work. There has been this discussion on here before. If I remember correctly the outer bearing on a 6 bolt hub is larger. You could always take your spindle to Eldale in Elmira and they will fix you up with a 6 bolt hub.
John WV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John WV Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 1:35pm
small ac combine has brass bushing not bearing in hub
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 2:01pm
Calvin, do you have anything apart over there to compare with?
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 2:21pm
D17s were made with both 5 & 6 bolt hubs, but I dont know if they used the same spindles if they do, I'm sure a D17 hub would work on a WD45.
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 6:16pm
I have 1959 D-17 with AC  pull combine hubs and a195745D with 6bolt WC hubs on.
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 11:14pm
My 58 D17 has 6 bolt hubs from a 190, had to find different outer bearings.
allisorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisorange Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 8:22am
          We have 6 bolt hubs off a junked model 100 combine.
                                John Carlson
