C steering problems
Toojeeps View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toojeeps Quote  Post ReplyReply Direct Link To This Post Topic: C steering problems
    Posted: 21 Jan 2011 at 10:09am
My Dad is restoring a C Allis that had a wide front end.  He is attempting to put the narrow front end back under the tractor.  It is the front end that was originally on the tractor.  He is aligning the witness marks according to the repair manual but when trying the steering it will turn nearly sideways to the left but only 15 to 20 degrees to the right.  If he moves the gears one tooth then the opposite occurs.   I know a little about old flatfender jeeps but have never worked on tractors very much so I am hoping someone on this forum may be able to help.  Thanks.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 11:10am
Does he have the radiator support off so he can look in at the gears to see the gears?  Kinda hard to do by feel. I would guess he is jumping more teeth than thought.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toojeeps Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 12:35pm
Yes, he has the support off and can see the alignment marks and they are aligned as pictured in the repair manual.
Robert Mull Georgia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robert Mull Georgia Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 12:39pm
With the Front end off make sure your steering wheel is centered. Then match up the witness marks.
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 2:29pm
Are you using the complete pedestal for the narrow front? Single front wheel & wide front use the same pedestal, but narrow front is different. Kip
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toojeeps Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 2:42pm
It is the narrow two wheel front end that came on the tractor.  Back in the late sixties Dad changed it to a wide front end so it would be safer for me to use.  He is now restoring it for my nephew and putting it back to original condition.  The narrow front end has been laying in a barn for 40 years.  Unless we changed something and don't remember, it should go back on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toojeeps Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2011 at 4:46pm
Turns out it was an alignment problem.  The gears were moving as he pushed the pedestal in place.  He bought two five inch bolts to hold everything in place while he started the factory bolts.  All went well and the steering turns as it should.  To all that responded thanks for the help.
Randy
