WHO MAKES A GOOD BODY FILLER
SIMPLICITY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Topic: WHO MAKES A GOOD BODY FILLER
    Posted: 20 Jan 2011 at 9:25pm
HELLO
   GETTING READY TO FIX RUST HOLES AND  RUST SPOTS ON 7060 HOODS AND CENTER PANEL. WHO MAKES A GOOD BODY FILLER AND IS EASY TO WORK WITH?
  THANKS THAD
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 6:33am
I prefer to use lead, short strand fibreglass is my second choice. Buy at a body paint supply shop that you get your paint from.
Key to a very good, long lasting job is surface prep! Get rid of all the old paint,scuff it up nice, clean it at least 3 times BEFORE you put anything on the metal.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 8:49am
evercoat medium base
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 9:10am
Where ya at Butch (OH)
I have used Butch's mixture and it works better than any other thing I ever tried. It also does not chip out of the pits when sanding like plain body filler will.
I have smoothed out some hoods that would have needed patched with anyother mixture.
I'll let Butch tell you the total deal. I want to give credit where credit is due.
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 9:20am
I like short strand fiberglass applied to bare metal, properly scuffed.  It does not attract water like most fillers.  It is a bit harder to work with.  Nothing more frustrating than to see blisters (rust) in the paint a couple years after doing all that work.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 9:40am
It's no big secrete Dick, LOL.
Best, easiest, fastest, cheapest way  depends on how deep they are. You should put some epoxy primer on first but its not mandatory. Then for deeply pitted metal you first use a thin bodied filler. It is sold under various names none of which I have committed to memory because I don’t buy them. I make my own by adding additional resin to regular body putty or bondo. Resin is sold at paint supply stores or the resin in a fiberglass patch kit is the same stuff. Add resin to bondo first and mix, then use the bondo hardener. If it "pulls up" behind whatever you use to smooth it leaving a rough surface you need more resin (pitch it and make another batch you don’t add resin to a batch already in the working stages or you'll have a mess to fix!) If it runs you overdid the resin, pitch and start over. Ordinary surfacer is used to finish the job with wet or dry sanding. Regular lacquer surfacers should not be used to fix deep pitting as the deep pockets do not dry for a long time and your nice smooth paint job will have  pits magically reappear in a few months. If you are wealthy enough to afford the two part surfacers you can pile it on as deep as you want.
 Guess I should have read the post better. My mix is for pits, not holes.
Edited by Butch(OH) - 21 Jan 2011 at 9:47am
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 11:51am
best fix for rust pits is primer.  just spray it let it dry sand it off . repeat process untill pit is full of primer and level with metal . you get no cracks that way . eavercoat medium weight body filler and plumbers sand cloth or cheesecloth makes holes go away untill next paint job. cheese cloth for holes you can stick your fist through small holes the body filler by itself will take care of .  Fiberglass risen added to it can  help to.
