Allis B trans hangs up
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Topic: Allis B trans hangs up
    Posted: 20 Jan 2011 at 9:16pm
I have a 38 B that gets stuck in two gears when shifting from 1st to reverse or vise versa and is a pain because you just have to platy with it until it comes unstuck so you can move again. It seems like it does it mostly going from 1st to reverse.
Thanks in advance for any help or ideas,
Denis
Edited by Denis in MI - 20 Jan 2011 at 9:17pm
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2011 at 10:43pm
Denis,  The B has a very reliable transmission.  That said 62 years of work is a lot for a tractor transmission.  If it is getting stuck in two gears I would consider removing the shifter arrangements.  Could be a problem there.  Perhaps new forks or detent balls, rods, or springs needed.  If I recall one can start by draining the oil and removing the shifter plate on the LH side of the transmission - facing front.  That should expose the problem and you could go from there.  Hopefully, the problem could be in the shifter arrangement.
Let us know how it goes.
Good Luck!
Bill Long
This page was generated in 0.273 seconds.
