Hyd pump removal 8000 series
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Topic: Hyd pump removal 8000 series
    Posted: 20 Jan 2011 at 6:54am
My hyd pump leaks where it goes into the transmisson housing. I&T manual shows how, but have any of you removed one before. This on a 8070 and it looks like there are 2 o rings that need to be changed. Thanks for any help!
Randy
niel ev View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote niel ev Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2011 at 9:29am
Randy there are 3 7/16 bolts that hold the pump in the rear end aand all the lines also the 10 3/8s bolts on the plate that you have to take down to get to the screen that has to come out before you try pulling the pump out also need to drain the oil and good luck the o riongs we been getting don't always stop the leak I think they send to small of rings Niel
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 6:45pm
Thanks for info, took everything apart, and replaced the o rings and hope they fix the leak. Thanks again
Randy
