camshafts
powertech84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Topic: camshafts
    Posted: 19 Jan 2011 at 5:58pm
Whats the difference between a wd camshaft and one from a d17? Anyone have the specs?
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2011 at 7:03pm
that will take the power is knowledge manual to be sure.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2011 at 7:43pm
  In  Pankese , that translates into Knowledge means power, the slogan AC put on the cover of their service manuals.
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2011 at 7:52pm
I'd bet a donut they're the same.Didn't change till 170's. My 220 and 8070 have same cam specs.
BrianC,Ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2011 at 8:23pm
I sent a D17 cam to the grinders in Toronto and had .100 more lift ground in. It is a 4 1/8 bore kit in the motor, and it dynoed 58 hp. Went from 120 lbs to 170 lbs cranking pressure. It has a whole different sound to it. We have a cam in the new motor that came from Barney Taylor, cant wait to get it on the dyno. I am going to check it on 2 different dynos to see what the results are.
Brian
35WC on steel, B with belly mower, D17 puller, D15 Series II puller, D15 Series II with loader, 608 Lawn Tractor
