WD-65 3 Point Conversion Update
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Topic: WD-65 3 Point Conversion Update
    Posted: 19 Jan 2011 at 3:58pm
Made the lift arm changes worked out great!update changes using the AC lift latches with the David Brown three point arms
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2011 at 3:58pm
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2011 at 3:59pm
Zyta View Drop Down
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2011 at 4:00pm
dsgraf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dsgraf Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2011 at 5:36pm
hmmmmmmm.. I like this! Are the links from a Ford?  What did the brackets come from that are on the lift arm hands?  Nice work?
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2011 at 7:56pm
The three point system/arms sway bar and bottom brackets which are not installed yet so not in the photo are off a David Brown. The two attachments pieces to the snap coupler arms are of an allis plow.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2011 at 9:25pm
I hope you have something to keep that 11 hole drawbar from twisting in the pull bar.
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2011 at 3:39pm
The 11hole drawbar is just sitting on the pull bar nothing finalized yet. I am still looking for good advise or examples of how to fabricate something down there to hold the arms. Still trying figure out how to make a good soild third link.
Jim
