Planting with a 8000 series ??? Turning??
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Topic: Planting with a 8000 series ??? Turning??
    Posted: 18 Jan 2011 at 7:42pm
Looking at putting my 8030 MFWD on the bean planter it is 20 ft. wide wondering how well that will work out??? Can it turn sharp enough?
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2011 at 10:35pm
You should be fine if your front and rear tires are to factory specs.
Mark
GTH-L Simplicity
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2011 at 11:03pm
I use my 8050 FWA to pull a 20' no till drill with no trouble, I use two rounds for turn rows on each end of the field.
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2011 at 10:19am
bump
Mike NEIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike NEIN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2011 at 10:34am
We used to pull a 15ft. with our 9190 and worked good.
