D17 with a 230 6 cly gas info
Jamie NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamie NC Quote  Post ReplyReply Direct Link To This Post Topic: D17 with a 230 6 cly gas info
    Posted: 17 Jan 2011 at 6:43pm
What all parts do I need to install a 230 gas 6cly in a D17 that was a 4 cly gas? frame rails,gonovers,ect. Thanks for in info that you guys can give me. I have a 230 engine and a D17 gas with no engine in it now. Thought it would be a neat project. Love tha sound of a gas 6 cly.
Allis tractor puller CA WC WD D17
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 8:05pm
Jamie, This was brought up a while back, and I think you also need to change the transmission input shaft.... it is too short in the 226 tractors ?  Maybe someone remembers,  Dr. Allis 's advice would be useful to you I'm sure.
E7018 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote E7018 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 9:13pm
You need the plate from the back of the block on a D17 diesel or D19, a flywheel from D17 diesel and clutch. I have the stuff. I was going to put a 262 gas in a D17 but I ended up putting in a 301 diesel. Frame rails need to be longer. I cut mine and added some length in the middle.  The transmission input shaft is 1 7/16 inch longer in a gas tractor than a diesel. I made a spacer plate to use up the distance on mine.
I am really happy about the way the 301 went into the tractor. I want spring to come so I can use it.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2011 at 12:20am
E7018, post a few pics of your beast that you built...please.
Post Options Post Options   Thanks (0) Thanks(0)   Quote E7018 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2011 at 6:25am
I  did. I can't make the search find it now. The title of the post was something like "F2 diesel engine - tractor". Posted about Christmas time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote E7018 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2011 at 6:30am
I found it.
http://www.allischalmers.com/new/forum/forum_posts.asp?TID=21247&KW=F2+tractor&PID=157202&title=f2-diesel-engine-tractor#157202
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2011 at 7:00am
Sorry about that, I went into Duh mode and when I seen the pics, I remembered seeingthose pics. Thanks for looking up and putting the link in.
