WD with picker, update 4, Maiden voyage
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Topic: WD with picker, update 4, Maiden voyage
    Posted: 16 Jan 2011 at 5:38pm
Hey all, another update. The Allis tires got to roll again under her own power since last october tonight. It did run fairly well so far, except she did flutter a couple times going down the road. I had to choke it a couple times to get her to fire up again. I think it could be a little crud in the carb, or maybe some water in the tank. I did look in the tank last fall and it looked clean. Also, I noticed that I have an oil leak at the rear of the oil pan. I did replace both main oil seals, so I think its the gasket for the pan. I didn't replace that, and am kickin myself for that now. Oh well, more time to wrench on the allis, gotta love it.
Also, I replaced the packings in one of the hydralic rams. What is the correct procedure to bleed the air out? I read the book, but thought it wasn't very clear.
Anyways, heres some pics from tonight...
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2011 at 7:50pm
Sharp.  I wish I were closer to see it when it's all finished.  I couldn't get dad talked out of his air cleaner cap.  I'm sure you'll find one somewhere.
AaronSEIA
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2011 at 8:07pm
lookin good Don !
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2011 at 8:24pm
You shouldn't have to bleed the cylinders. Run the up and down a few times and they should work fine. I guess that might be harder to do without the lift arms connected.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 11:42am
AaronSEIA
Thanks Aaron, Ricks got one headed my way soon.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 1:14pm
Don...I would think that you should have the air cleaner cap by tomorrow,I hope. I sent it off Friday,so let me know,please.  Thanks,Rick
