cylinder head interchange?
redline View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Topic: cylinder head interchange?
    Posted: 16 Jan 2011 at 1:45pm
Do the D17 heads, WD, and the WD45 heads interchange? I have a WD with the tall head (4") that needs a replacement. Will a D17 head fit on it? I understand the pushrods and some other stuff is different between the tall and short heads, but I already have the tall one. (which is a bit of a shame since I have a very good short head on hand)
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2011 at 1:47pm
same head gasket from WC to 170 so I would think so
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2011 at 1:49pm
rocker arm posts and valve cover are different from a tall to a short, but the rest will swap out easily
if you are going from a 4" head to another, it's as simple as changing it
Edited by wi50 - 16 Jan 2011 at 1:50pm
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2011 at 1:50pm
I've got what I think is a D17 head that I know dad took off of his WD.  It's for sale if you need a head.
AaronSEIA
