WD45 Spin Out Wrench
dannyraddatz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Spin Out Wrench
    Posted: 15 Jan 2011 at 7:02pm
I bought a wrench but it had no handle, can some one help me out with what type of steel rod and maybe a picture.
Thanks,
Danny
Danny Raddatz
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2011 at 7:36pm
Like this?  Found these in the WD toolbox-cleaned them and painted them.
Greg Kroeker
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2011 at 7:59pm
I want to know how loose the eccenterics have to be for that hand wrench to work.  I need my impact and/or a 1/2 drive breaker bar to make mine turn.  Someday I'm gonna take them off and clean them up nice so something like the correct wrench will work them.  Then I'll need to find the correct wrench.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2011 at 8:19pm
Greg,
That's the one, how long is the bar? and is the end flattened so it woun't slide all the way threw the wrench?
Danny
Danny Raddatz
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2011 at 8:42pm
Aaron, Dad tells me they only worked for a short time, when the tractor was new LOL!Danny, the rod is approximately 1 inch shorter than the wrench, and, yes, the one end is flattened!
Greg Kroeker
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2011 at 9:21pm
Thats what I'm thinking.  I see them do it on the old videos and it looks like my 3 1/2 year old could run the wrench.  Anyone here farm with them new remember moving the wheels as much as they say in the videos?
AaronSEIA
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2011 at 9:47pm
I still use a set with my '45 to move the wheels in and out a couple of times a year.  Move them in for the plow and in the winter with the blade.  Move them out in the spring for the planter and cultivator.  Everything moves properly.  The tractor was always shedded, so that may help.  Dave
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2011 at 1:52pm
Danny, I use a tire spoon bar for my bar, they are longer than the right bar and give more leverage. Not just use a plain old piece of round bar like re-bar they are not strong enough and will just bend. I've been there tried that. lol
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2011 at 1:55pm
I move mine out for the blade (more room for the chains) and in in the summer.  Mine has been inside as well, but it takes an impact to get mine to move.  I just need to take them off and clean them up good.
AaronSEIA
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2011 at 3:01pm
My WD45 lasts has been dissasembled and painted I can move with a 1/2 Inch ratchet and socket. the Othe tractor I couldn't  move with a 3/4 breaker bar with a 4 ft. cheater. I did manage to sanp one off though.
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2011 at 4:12pm
Back in the early 70's we had 4 of then,( 2 17's 2 45's ) that we we had to move in and out  twice a year. I was only about 10 or 12   when I was tapped to do one of them myself. The onlly thing we used back then was the wheel wrench  in the tool box. The biggest deal was catching h#ll for not getting the rear wheels straight. And I  mean STRAIGHT ! Looking back I suppose it was just another lesson on doing a job the right way..
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2011 at 5:26pm
I think some of the replacement rims are a little tighter, too.  Some tractors there is no way to get all four locked all the way without breaking something.
ALLIS EXPRESS!
This year:
Reeseholler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reeseholler Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2011 at 5:55pm
I have a feeling that's what I'm going to run into with my rim. It's hard to get the hub into the eccentrics so it could be tricky getting them tight. After spraying PB Blaster around the head of the eccentric and after about an hour of turning with a breaker bar, I can turn mine with my fingers and when they're on, with the wheel wrench.
This page was generated in 0.073 seconds.
