ADD PICTURES
RGR(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RGR(TX) Quote  Post ReplyReply Direct Link To This Post Topic: ADD PICTURES
    Posted: 15 Jan 2011 at 5:15pm
PLEASE TELL ME HOW TO ADD PICTURES TO REPLY.
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2011 at 5:36pm
For me, it works best to have them in Photobucket-it is free to do so.  Then,  when you reply, you DON'T do the quick reply, you use the Post Reply option.  In that screen there will be a button to insert image-use the IMG code from your photobucket account.
Greg Kroeker
Post Options Post Options   Thanks (0) Thanks(0)   Quote RGR(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2011 at 5:41pm
OK HOW DO YOU LOAD AND RETRIEVE FROM PHOTOBUCKET?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2011 at 6:13pm
You have to get on photobucket and get an account.   Once you have one and are in your account, there is a button on the top of the screen that has "upload picture"  on it.  You have to click on that and then find where the specific picture is that you want to load up and select it, and then it will load up on photobucket.   Then you can go into your pictures and select the IMG Code that is under the picture when you drag the pointer over it.   If you left click on it, it will copy it.   Then when you post on here, you just right click and paste it where you are typing.   It's best to hit enter and paste it on it's own line, so that your text will be above it.     Hope that helps.
