HD10 Engine type |
Uncle Grumpy
Topic: HD10 Engine typePosted: 14 Jan 2011 at 10:09pm |
Hi,
I wanted to know if the GM 4-71 used in the HD10 is the low block version or is it the later High Block? Is there a Allis model that uses the low block? Cheers |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42274 |
Posted: 16 Jan 2011 at 10:26am |
Unsure of designation on the engine in block , as the date of this would be pre 1955 guess one could look up when the change was made.
E7018
Posted: 17 Jan 2011 at 9:40am |
One change was on the serial number plate. Before 1947, the designation was 71, after it was A. The change from low block to high block was about then. I ain't for sure, long time ago.
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35705 |
Posted: 17 Jan 2011 at 6:09pm |
When Detroit changed the piston/rod design in the engines during the big drive to put them in trucks they changed the blocks, I believe that was in 49. Previous to then these engines were only destined for marine and industrial applications.
